Banana Pi BPI-M4
Revision as of 23:54, 25 June 2019 by Sinovoip (talk | contribs) (Software)
File:Banana Pi BPI-M4 3.JPG
Overview:Realtek RTD1395
PoE function support
M.2 and PCIE support
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Getting Started with M4
Size & Weight 92x60mm, 48g
OS Android and Linux
CON1-P02 DCIN
CON1-P03 I2C1_SDA GPIO-17
CON1-P04 DCIN
CON1-P05 I2C1_SCL GPIO-16
CON1-P07 PWM1 GPIO-21
CON1-P08 UR1_TX GPIO-9
CON1-P10 UR1_RX GPIO-8
CON1-P11 SDIO-D0 GPIO-42
CON1-P12 AIO_BCK GPIO-3
CON1-P13 SDIO-D1 GPIO-43
CON1-P15 SDIO-D2 GPIO-44
CON1-P16 UR1_RTS GPIO-11
CON1-P18 UR1_CTS GPIO-10
CON1-P19 GSPI-MOSI GPIO-31
CON1-P21 GSPI-MISO GPIO-18
CON1-P22 GPIO-47 GPIO-47
CON1-P23 GSPI-SCK GPIO-19
CON1-P24 GSPI-CS GPIO-20
CON1-P26 PWM2 GPIO-22
CON1-P27 SDIO-D3 GPIO-45
CON1-P28 PWM3 GPIO-23
CON1-P29 SDIO-CLK GPIO-41
CON1-P31 SDIO-CMD GPIO-40
CON1-P32 SPDIF GPIO-50
CON1-P33 AIO_CK GPIO-4
CON1-P35 AIO_LRCK GPIO-2
CON1-P36 GPIO-53 GPIO-53
CON1-P37 GPIO-34 GPIO-34
CON1-P38 AI_SD GPIO-5
CON1-P40 AO_SD GPIO-6
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Source code on github: https://github.com/BPI-SINOVOIP/BPI-M4-bsp
documents
  • BPI-M4 schematic diagram:
google driver:https://drive.google.com/file/d/1A6pj8Y9Ru1_qfMapIdiQnMavEs5xzN5H/view?usp=sharing
Baidu cloud:https://pan.baidu.com/s/1mnn51dwBV5uxpNheBD4vJA pincode: t6cd
google driver: https://drive.google.com/file/d/1xK-DAjdjXiY7BgGcmq7x-aL5g6djznqT/view?usp=sharing
baidu cloud : 链接: https://pan.baidu.com/s/1bSZFMJ2lD_zuQru6Lf27RQ Pincode: 6pb8
  • 2019-6-25 update ,This release is for BPI-M4 which is based on rtd1395,Image is Android 8.1.0 with kernel 4.9.119.
Features Map:http://wiki.banana-pi.org/M4_Image_Map#Android_8.1_HDMI
Baidu Drive:https://pan.baidu.com/s/1KyTVmNX6LZtxqkRSQR9HMw (PinCode:9mwg)
Google Drive:https://drive.google.com/open?id=12wB3CqGBDxE7Cyi_BzZbAid0UlZCtcFZ
For detail steps please see here:http://wiki.banana-pi.org/Getting_Started_with_M4#Install_Android
Forum pthread:http://forum.banana-pi.org/t/bpi-m4-android-8-1-demo-image-release-2019-06-25/9401
Ubuntu linux
Raspbian Linux
AArch Linux
Fetures Map:
  • AArch64 Linux Lite
Fetures Map:
