Getting Started with W2
Revision as of 01:27, 23 May 2019 by JackZengWiki (talk | contribs) (WiFi & BT)
Overview: BPI-W2 Android 6.0
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Load your first image on W2
 * apt-get install pv
 4.After step 3, then you can insert your TF card into W2, and press power button setup W2.
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
WiFi & BT
STA
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP
File:RTL8822BE AP.jpg
Develop 4G module with W2
Make your own image
