Getting Started with W2
Overview: BPI-W2 Android 6.0
Debian 9 Linux Image Release 2018-09-18
BananaPI-W2 Ubuntu 18.04 New Image Release 2018-09-17
BananaPI-W2 Raspbian 9.4 New Image Release 2018-09-17
RPiTCv3_1.12-demo-bpi-w2-beta-2018-09-03
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Load your first image on W2
 * apt-get install pv
 4.After step 3, then you can insert your TF card into W2, and press power button setup W2.
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SATA
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
AP mode
Develop 4G module with W2
Make your own image
