Banana Pi BPI-M2U
Banana Pi BPI-M2 Ultra is a quad-core mini single board computer built with Allwinner R40/V40 SoC. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port.. Also being a member of the Banana Pi family, the M2 Ultra is a direct upgrade from the Banana Pi M1/M1+ that support SATA from the SoC. The SATA performance on the R40 is fitting for media related projects such as storage servers. Backed by our community, starting a project and building servers is fun and rewarding. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
- Allwinner R40/V40 Quad Core ARM Cortex A7 CPU
- 2GB DDR3 SDRAM.
- 8GB eMMC flahs onboard.
- SATA Interface.
- 2*USB 2.0
- MIPI DSI ingerface
- CSI camera interface
File:BPI-M2 Ultra interface.jpg
HardWare Specification of Banana pi BPI-M2 Ultra | |||
Soc | Allwinner R40/V40 | ||
CPU | quad-core cortex -A7,the most power efficient CPU core ARM's ever development | ||
GPU | dual-core MALI-400 MP2 and runs at 500MHz, capable of 1.1 Gpixel/s throughput. Graphics capabilities are slightly higher than the original Xbox’s level of performance. The GPU provides OpenGL ES 2.0, hardware-accelerated OpenVG, 1080p45 H.264 high-profile encode and decode. | ||
SDRAM | 2 GB DDR3 with 733MHz\(shared with GPU\) | ||
SATA | suppoort SATA interface | ||
On board Network | 10/100/1000Mbps Ethernet \(Realtek RTL8211E/D\) | ||
Wifi Module | WiFi 802.11 b/g/n \(AP 6212 module on board\) | ||
Bluetooth | BT4.0 | ||
Display | 4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4 | ||
Video | Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,support video encodeing:High-deinition\(HD\)H.264 video encoder is up to 1080P@45fps | ||
Audio outputs | HDMI, analog audio \(via 3.5 mm TRRS jack\) | ||
Camera | A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps | ||
Audio input | On board microphone | ||
USB | 2 USB 2.0 host, 1 USB 2.0 OTG | ||
Buttons | Reset button, Power button, U-boot button | ||
IR | onboard IR receiver | ||
DC Power | 5V/2A with micro USB port | ||
battery | 3.7V lithium battery power support | ||
Sizes | 85mmX56mm,same size as raspberry pi 3 | ||
Weight | 40g |
40 PIN GPIO of Banana pi BPI-M2 Ultra | |||
CON1-P01 | VCC-3V3 | ||
CON1-P02 | DCIN | ||
CON1-P03 | TWI2-SDA | PB21 | PWM5 |
CON1-P04 | DCIN | ||
CON1-P05 | TWI2-SCK | PB20 | PWM4 |
CON1-P06 | GND | ||
CON1-P07 | PB3 | PB3 | PWM1 |
CON1-P08 | UART2-TX | PI18 | SPI1\_MOSI |
CON1-P09 | GND | ||
CON1-P10 | UART2-RX | PI19 | SPI1\_MISO |
CON1-P11 | UART7-TX | PI20 | PWM2 |
CON1-P12 | UART2-CTS | PI17 | SPI1\_CLK |
CON1-P13 | UART7-RX | PI21 | PWM3 |
CON1-P14 | GND | ||
CON1-P15 | PH25 | PH25 | CSI1-FIELD |
CON1-P16 | UART2-RTS | PI16 | SPI1\_CS0 |
CON1-P17 | VCC-3V3 | ||
CON1-P18 | PH26 | PH26 | CSI1-HSYNC |
CON1-P19 | SPI0\_MOSI | PC0 | |
CON1-P20 | GND | ||
CON1-P21 | SPI0\_MISO | PC1 | |
CON1-P22 | PH27 | PH27 | CSI1-VSYNC |
CON1-P23 | SPI0\_CLK | PC2 | |
CON1-P24 | SPI0\_CS | PC23 | |
CON1-P25 | GND | ||
CON1-P26 | PH24 | PH24 | CSI1-PCLK |
CON1-P27 | TWI3-SDA | PI1 | |
CON1-P28 | TWI3-SCK | PI0 | |
CON1-P29 | PH0 | PH0 | CSI1-D0 |
CON1-P30 | GND | ||
CON1-P31 | PH1 | PH1 | CSI1-D1 |
CON1-P32 | PD20 | PD20 | CSI1-MCLK |
CON1-P33 | PH2 | PH2 | CSI1-D2 |
CON1-P34 | GND | ||
CON1-P35 | PH3 | PH3 | CSI1-D3 |
CON1-P36 | UART5-RX | PH7 | CSI1-D7 |
CON1-P37 | UART4-TX | PH4 | CSI1-D4 |
CON1-P38 | UART5-TX | PH6 | CSI1-D6 |
CON1-P39 | GND | ||
CON1-P40 | UART4-RX | PH5 | CSI1-D5 |
CSi Camera connector GPIO of Banana pi BPI-M2 Ultra | |||
CN5-P01 | NC | ||
CN5-P02 | GND | ||
CN5-P03 | CSI0-SDA | PI3 | |
CN5-P04 | CSI0-AVDD | ||
CN5-P05 | CSI0-SCK | PI2 | |
CN5-P06 | CSI0-Reset | PI7 | |
CN5-P07 | CSI0-VSYNC | PE3 | |
CN5-P08 | CSI0-PWDN | PI6 | |
CN5-P09 | CSI0-HSYNC | PE2 | |
CN5-P10 | CSI0-DVDD | ||
CN5-P11 | CSI0-DOVDD | ||
CN5-P12 | CSI0-D7 | PE11 | |
CN5-P13 | CSI0-MCLK | PE1 | |
CN5-P14 | CSI0-D6 | PE10 | |
CN5-P15 | GND | ||
CN5-P16 | CSI0-D5 | PE9 | |
CN5-P17 | CSI0-PCLK | PE0 | |
CN5-P18 | CSI0-D4 | PE8 | |
CN5-P19 | CSI0-D0 | PE4 | |
CN5-P20 | CSI0-D3 | PE7 | |
CN5-P21 | CSI0-D1 | PE5 | |
CN5-P22 | CSI0-D2 | PE6 | |
CN5-P23 | GND | ||
CN5-P24 | CSI0-AFVCC |
Display specification
CN6-P01 | VCC-3V3 | ||
CN6-P02 | IPSOUT | ||
CN6-P03 | VCC-3V3 | ||
CN6-P04 | IPSOUT | ||
CN6-P05 | GND | ||
CN6-P06 | IPSOUT | ||
CN6-P07 | GND | ||
CN6-P08 | IPSOUT | ||
CN6-P09 | NC | ||
CN6-P10 | GND | ||
CN6-P11 | NC | ||
CN6-P12 | DSI-D0N | ||
CN6-P13 | NC | ||
CN6-P14 | DSI-D0P | ||
CN6-P15 | NC | ||
CN6-P16 | GND | ||
CN6-P17 | TWI0-SDA | PB19 | |
CN6-P18 | DSI-D1N | ||
CN6-P19 | TWI0-SCK | PB18 | |
CN6-P20 | DSI-D1P | ||
CN6-P21 | CTP-INT | PI10 | |
CN6-P22 | GND | ||
CN6-P23 | CTP-RST | PI11 | |
CN6-P24 | DSI-CKN | ||
CN6-P25 | GND | ||
CN6-P26 | DSI-CKP | ||
CN6-P27 | LCD-BL-EN | PH16 | |
CN6-P28 | GND | ||
CN6-P29 | LCD-RST | PH17 | |
CN6-P30 | DSI-D2N | ||
CN6-P31 | LCD-PWR-EN | PH18 | |
CN6-P32 | DSI-D2P | ||
CN6-P33 | GND | ||
CN6-P34 | GND | ||
CN6-P35 | LCD-PWM | PB2 | |
CN6-P36 | DSI-D3N | ||
CN6-P37 | GND | ||
CN6-P38 | DSI-D3P | ||
CN6-P39 | NC | ||
CN6-P40 | GND |
CON4 Uart GPIO of Banana pi BPI-M2 Ultra | |||
CON2 P03 | UART0-TXD | ||
CON2 P02 | UART0-RXD | ||
CON2 P01 | GND |
- Banana Pi BPI-M2 Ultra / BPI-M2 Berry How to alter Uboot、Kernel
- How to boot from emmc with SD data
- How to rebuild bootloader BPI_M2U_720P-emmc.img.gz
- Supports Banana Pi BPI-M2 Ultra (R40) (Kernel3.10)
- BPI official github:https://github.com/BPI-SINOVOIP/BPI-M2U-bsp
- other github for BPI-M2 Ultra /Berry : https://github.com/facat/BPI-M2U-bsp
- BPI-M2 Ultra/Berry TinaLinux github https://github.com/tinalinux/linux-3.10
- Schematics BPI-M2 Ultra Schematics
- Allwinner R40/V40 datasheet
Android 6.0
- 2018-12-28 update
- HDMI-Version
- BaiDu Drive:https://pan.baidu.com/s/1_ec1SHxr87lV9j9sJ_vTkg PinCode:gavs
- LCD7-Version
- BaiDu Drive:https://pan.baidu.com/s/1vGiLql0-WSGMqQFMFjtMRA PinCode:wqt6
- 2017-08-25 update
- HDMI-Version
MD5: c65fa4c20b8a6d2d05bfd32b090c3570
- LCD5-Version
MD5:f664e5fe0af20ebfc06ddc50bac1845b
- LCD7-Version
MD5: 6cda3453d9524643c8f92fcdc8deb32f
3.10 kernel
- baidu cloud : 链接:https://pan.baidu.com/s/1xRReFsjaOAYx9xEl0_BNWA PinCode:myu5
- 2017-11-13 update
- baidu cloud : 链接:https://pan.baidu.com/s/1xls34tILr9f4I5FUZ1Gtpw PinCode:trmk
- 2017-11-13 update debian-9-stretch-mate-desktop
- Google Drive : https://drive.google.com/file/d/0B_YnvHgh2rwjeTh4TmlnMGl5X3M/view?usp=sharing
- baidu cloud : 链接:https://pan.baidu.com/s/1Kv2S0TqUX49rEbbQgiP_bQ PinCode:v6m4
- MD5: 0a1fad281c24902148b16276a79bac12
- 2017-11-13 update debian-9-stretch-lite
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjOWg1OW9heWZsYm8/view?usp=sharing
- baidu cloud: 链接:https://pan.baidu.com/s/1gE0a4ckTRrRXRbIX8uQzNg PinCode:5vnb
- MD5: cff677aa94ca5345fc6e26379cfe4e95
- forum pthread : http://forum.banana-pi.org/t/bpi-m2-ultra-bpi-m2-berry-new-image-2017-08-28-debian-sd-emmc-img/3745/2
Rasbian
- 2017-05-25 update raspbian jessie
- Google Drive :https://drive.google.com/open?id=1Ntdh5tMyCjiAu8bBC9NC2ShEAYAAD0tD
- baidu cloud : 链接:https://pan.baidu.com/s/1i4YdcBeVvMyl530WHzArzA PinCode:l1rn
- MD5: 60e19ea9138d6841fa6852ece4727b0a
- forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m2-ultra-bpi-m2-berry-new-image-2017-05-25-raspbian-jessie-preview3-bpi-m2u-sd-emmc-img/3306
Tina IoT Linux
RPiTC v3 1.12
- 2017-11-28 updtae
Others
