BPI:bit for Arduino
Revision as of 20:56, 23 February 2019 by Sinovoip (talk | contribs) (How to use with Platform IO)
Overview: BPI-Bit
BPI-UNO32 with ESP32 design
About BPI:bit
More about Banana Pi BPI:bit,please see :BPI-Bit
BPI:bit for Arduino-IDE
BPI:bit for Arduino IDE source code
Wired connection board
Development extension package
Windows installation instructions
  • Download and install the latest version of the Arduino IDE, Windows Installer from arduino.cc
  • Unzip the Arduino expansion package: [ARDUINO_SKETCHBOOK_DIR]/hardware/espressif/esp32
ARDUINO_SKETCHBOOK_DIR:generally is C:/Users/[YOUR_USER_NAME]/Documents/Arduino listed below the "Sketchbook location" in the Arduino preference
  • In turn open directory [ARDUINO_SKETCHBOOK_DIR]/hardware/espressif/esp32 /tools, and double-click the get operation. Exe
  • When get.exe runs out, you should see the following files in the directory
  • Insert the BPI:bit board and wait for the driver to install (or manually install) Serial CH341
  • Run the Arduino IDE
  • Select your version (bpi-bit) Tools>Board menu
  • Select the COM port to which the BIT board is connected, such as COMx
  • Compile and upload your engineering code (BIT board design has automatic recording circuit, just click to upload)
Debian/Ubuntu Linux OS installation instructions
  • Get and install the latest version of the arduino IDE from the arduino.cc website
  • Open the terminal and execute the following command (copy-> paste and click enter):
sudo usermod -a -G dialout $USER && \
sudo apt-get install git && \
wget https://bootstrap.pypa.io/get-pip.py && \
sudo python get-pip.py && \
sudo pip install pyserial && \
mkdir -p ~/Arduino/hardware/espressif && \
cd ~/Arduino/hardware/espressif && \
git clone https://github.com/espressif/arduino-esp32.git esp32 && \
cd esp32 && \
git submodule update --init --recursive && \
cd tools && \
python2 get.py
  • Restart the Arduino IDE
  • If you have installed arduino to ~/directory, please execute the following code. If not, please start from mkdir-p ~/ arduino /hardware:
mkdir -p espressif && \
cd espressif && \
cd esp32 && \
cd tools && \
python2 get.py
Mac OS install arduino IDE
cd esp32 && \
cd tools && \
python2 get.py
The ~/Documents/Arduino directory should be consistent with the "Arduino" > "preference" > "Sketchbook location" (after the software starts). You may need to change the above command if you need to!
If you receive the following error. Use xcode-select --install to install the command-line development tool and try the above command again:
xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun
How to development with BPI:bit
Arduino IDE Programing Function Define
Function IO
RGB_LED IO4
RGB_LED_POWER IO2
BUZZER IO25
BOTTON_A IO35
BOTTON_B IO27
TEMPERTURE_SENSOR IO34
MPU9250_AD0 IO0
Communication Protocol
SPI
MISO IO19
MOSI IO23
SCK IO23
SS IO5
I2C
SCL IO22
SDA IO21
How to use with Arduino IDE
Lighting the RGB LED
Source code at github
