1 The basic algorithm
Revision as of 06:39, 21 February 2019 by Sinovoip (talk | contribs)
Implement the basic algorithm
After we learned some basic hardware controls in the last chapter, let's make up our basic software lessons.
Enter the year to determine the leap year
A leap year is a noun in the Gregorian calendar. Common year: a year that is divisible by 4 but not by 100 is a common leap year. (2004 is a leap year, 1999 is not); Century years: leap years are those divisible by 400.
The code is as follows :(can be placed in main.py):
def is_leap_year(year):
   if (year % 4) == 0 and (year % 100) != 0 or (year % 400) == 0:
		print("{0} is leap year".format(year))
	else:
		print("{0} not is leap year".format(year))
first in the interpreter using runfile main.py and then run it in the repl
is_leap_year(int(input("input a leap year ")))
  • The year 2004 is leap year.
  • The year 1999 is not leap year.
  • The year 2000 is leap year.
  • You can also go ahead and type in more and have it tell you which year is a leap year.
When you type a command in REPL, you are prompted to enter a value, and press ok to confirm the input.
Fibonacci sequence
