BPI:bit for Arduino
About BPI:bit
More about Banana Pi BPI:bit,please see :BPI-Bit
BPI:bit for Arduino-IDE
Wired connection board
Development extension package
Windows installation instructions
  • Download and install the latest version of the Arduino IDE, Windows Installer from arduino.cc
  • Unzip the Arduino expansion package: [ARDUINO_SKETCHBOOK_DIR]/hardware/espressif/esp32
ARDUINO_SKETCHBOOK_DIR:generally is C:/Users/[YOUR_USER_NAME]/Documents/Arduino listed below the "Sketchbook location" in the Arduino preference
  • In turn open directory [ARDUINO_SKETCHBOOK_DIR]/hardware/espressif/esp32 /tools, and double-click the get operation. Exe
  • When get.exe runs out, you should see the following files in the directory
  • Insert the BPI:bit board and wait for the driver to install (or manually install) Serial CH341
  • Run the Arduino IDE
  • Select your version (bpi-bit) Tools>Board menu
  • Select the COM port to which the BIT board is connected, such as COMx
  • Compile and upload your engineering code (BIT board design has automatic recording circuit, just click to upload)
Debian/Ubuntu Linux OS installation instructions
  • Get and install the latest version of the arduino IDE from the arduino.cc website
  • Open the terminal and execute the following command (copy-> paste and click enter):
sudo usermod -a -G dialout $USER && \
sudo apt-get install git && \
wget https://bootstrap.pypa.io/get-pip.py && \
sudo python get-pip.py && \
sudo pip install pyserial && \
mkdir -p ~/Arduino/hardware/espressif && \
cd ~/Arduino/hardware/espressif && \
git clone https://github.com/espressif/arduino-esp32.git esp32 && \
cd esp32 && \
git submodule update --init --recursive && \
cd tools && \
python2 get.py
  • Rerun the Arduino IDE
  • If you have installed arduino to ~/directory, please execute the following code. If not, please start from mkdir-p ~/ arduino /hardware:
mkdir -p espressif && \
cd espressif && \
cd esp32 && \
cd tools && \
python2 get.py
Mac OS install arduino IDE
