2 ESPBlocks Beginner's only
Program with ESPBlocks
The development tools
Connect the board
  • Windows for example, in any location directly run, it is recommended that there is no Chinese path.
  • Double-click to open ESPblocks. Exe and wait for a moment while it releases the resource
  • Whether or not there is a Connect board, the Connect search board will pop up once, or you can click on the Connect to pop up the window.
  • Now we connect the board through the wire, it will automatically find the current connected board serial port and display, as shown in the figure below.
  • Then click the button in the figure to confirm that it is their own board can be connected.
  • the connection is completed as shown below:
  • Wireless connection is not supported now
Use the Editor to run the program
  • Prepare a piece of code and copy it into the white box.
print('\n')
print('test')
print('\n')
  • Click the Run button to complete the Run
Use Blockly to run the program
  • Follow the arrows in the figure below.
  • When you click the Blockly button in the menu, a fixed size window pops up. This function cannot be reused at present, so you need to close the program to use it again.
  • Select one of the display interface blocks in Blockly and it will appear synchronously in the edit box on the right, but you cannot edit code in Blockly mode.
