Banana Pi BPI-M4
Revision as of 03:09, 13 February 2019 by Sinovoip (talk | contribs) (→Introduction)
Banana Pi BPI-M4 use Realtek RTD1395 chp design ,it is a 64-bit quad-core A53 mini single board computer. It features 1 GB of RAM and 8 GB eMMC. It also has onboard WiFi for b/g/n/ac and BT 4.2. On the ports side, the BPI-M4 has 4 USB 2.0 ports, 1 USB TYPE C port, 1 HDMI port, 1 audio jack.
  • Mali 470 MP4 GPU OpenGL ES 1.1/2.0
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
HardWare Specification of Banana pi BPI-M64
Video Output(s) 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Power Source 5 volt @2A via DC Power and/or Micro USB (TYPE C)
Size & Weight 92x60mm, 48g
OS Android and Linux
