Banana Pi BPI-M64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
  • Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2 GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
Banana Pi M64
CPU Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU
GPU Dual core Mali 400 MP2 GPU
Storage MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G)
Network 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0
Video Output(s) high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO of Banana pi BPI-M64
GPIO Pin Name| Default Function|Function2:GPIO|Function3|
-- | VCC-3V3     VCC-5V     TWI1-SDA| PH3|   VCC-5V     TWI1-SCK| PH2|   GND     PH6| PH6|   UART2-TX| PB0|   GND     UART2-RX| PB1|   PH7| PH7|   UART2-CTS| PB3 |  DMIC-CLK| PH10|   GND     DMIC-DIN| PH11|   UART2-RTS| PB2|   VCC-3V3     PD4| PD4 |  SPI1-MOSI| PD2| UART4-TX| GND     SPI1-MISO| PD3| UART4-RX| PC0| PC0|   SPI1-CLK| PD1| UART3-RX| SPI1-CS |PD0| UART3-TX| GND     PC2| PC2   PC4| PC4   PC3| PC3   PC7| PC7   GND     PCM0-BCLK| PB5 PCM0-DIN| PB7 |  PCM0-SYNC| PB4 |  GND     PCM0-DOUT| PB6   PL9| PL9 |  PL12| PL12|   PL7| PL7 |  GND     PL8| PL8 |
    • CSI Camera Connector specification:**
CSI camer PIN define of Banana pi BPI-M64
Default Function| Function2:GPIO| -- | NC|   GND|   CSI0-SDA| PE13| CSI0-AVDD|   CSI0-SCK| PE12| CSI0-Reset| PE16| CSI0-VSYNC| PE3| CSI0-PWDN| PE17| CSI0-HSYNC| PE2| CSI0-DVDD|   CSI0-DOVDD|   CSI0-D7| PE11| CSI0-MCLK| PE1| CSI0-D6| PE10| GND|   CSI0-D5| PE9| CSI0-PCLK| PE0| CSI0-D4| PE8| CSI0-D0| PE4| CSI0-D3| PE7| CSI0-D1| PE5| CSI0-D2| PE6| GND |  CSI0-AFVCC
    • Display specification:**
MIPI DSI display PIN define of Banana pi BPI-M64
Default Function| Function2:GPIO| -- | VCC |  IPSOUT|   VCC |  IPSOUT|   GND|   IPSOUT |  GND   IPSOUT |  NC |  GND   NC |  DSI-D0N   NC |  DSI-D0P   NC |  GND   TWI0-SDA| PH1| DSI-D1N |  TWI0-SCK| PH0| DSI-D1P   CTP-INT| PH4| GND|   CTP-RST| PH8| DSI-CKN |  GND   DSI-CKP |  LCD-BL-EN| PD5| GND   LCD-RST |PD6| DSI-D2N |  LCD-PWR-EN |PD7| DSI-D2P |  GND   GND |  LCD-PWM| PL10| DSI-D3N   GND   DSI-D3P |  NC   GND
    • UART specification:**
Uart PIN define of Banana pi BPI-M2+
Default Function| GPIO| -- | UART0-TXD| PB8| UART0-RXD| PB9| GND |
Opnewrt
TinaLinux
Release
