Banana Pi BPI-R64
产品介绍
MTK MT7622 芯片
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi on board
- support 1 SATA interface
- (1) USB 3.0
- POE function support
硬件接口示意
| Banana pi BPI-R64 硬件规格 | |||
| SDRAM | 1 GB DDR3 | ||
| SATA | support 1 SATA interface | ||
| On board Network | 5 10/100/1000Mbps Ethernet | ||
| USB | 1 USB 3.0 host | ||
| Buttons | Reset button | ||
| Weight | 100g | ||
PoE 网线供电支持
more PoE module spec
BPI-R64 GPIO Pin define
