BPI-UNO32 Arduino开发板
Revision as of 00:13, 31 October 2018 by Sinovoip (talk | contribs) (Resources)
产品介绍
Overview:BPI-UNO32 with ESP32
BPI-Bit with ESP32 design
The BPI:UNO32 (also referred to as BPI-UNO32, stylised as BPI UNO32) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system. support Webduino and arduino function.
BPI-UNO32 uses the ESP-WROOM-32 of espressif company as MCU. ESP32 is a single-chip solution integrating 2.4GHz Wi-Fi and Bluetooth dual mode. The 40 nanometer technology of TSMC has the best power consumption, RF performance, stability, versatility and reliability. It can deal with various application scenarios.
Two separate controlled CPU cores, the main frequency can be up to 240MHz, 448KB ROM, 520KB SRAM.
BPI-UNO32 The appearance size is fully matched with Arduino UNO R3
BPI:UNO32 硬件
BPI:UNO32 硬件接口
BPI:UNO32 硬件规格
BPI:uno32 硬件规格
CPU Xtensa® 32-bitLX6single / dual core processor
ROM 448KB
SRAM 520KB
Flash 4MB(Onboard),A maximum of 4 Flash/SRAM, each Flash maximum 16MB
Power 5V@1AmicroUSBpoweror 5.5mm 12VDCport
GPIO 12-bits SAR ADC 18 channel, 2\*8-bit D/A converter, 4*SPI, 2*I2S, 2*I2C, 3*UART, Host SD/eMMC/SDIO, Slave SDIO/SPI
Wi-Fi 802.11 b/g/n/e/i 802.11 n\(2.4GHz 150Mbps\) 802.11 e\(Quality of Service\)
Bluetooth BT4.2 & BLE
Buzzer Passive buzzer
LEDs RGB LED/POWER LED/Receive LED/Transmit LED
Sizes 68mm\*53mm
BPI:UNO32 PIN 定义
BPI-UNO32 软件开发
Visuino
About Visuino
Visuino is a visual, graphical development environment for Arduino and similar boards, including almost all standard Arduino boards, Teensy, Femto IO, LinkIt ONE, FreeSoC2, RoMeo BLE, Bluno Beetle, Goldilocks Analogue, ESP8266, ESP32, PIC32, nRF52832, Maple Mini, and many Arduino based Industrial PLC Controllers such as Controllino, Bedac, and Digital Loggers PLDuino, and Industrial Shields.
Programming with Visuino is as easy as picking components from the Components Toolbar, placing them in the Visual Design Area, connecting them, and setting their properties with the Object Inspector. The Overview, allows easy navigation over big designs, and Visuino includes built-in Communication Terminal, Scope, and Gauges, and other Visual Instruments to monitor and display the data sent from Arduino. It allows creating complex industrial automation, and IoT solutions by simply dropping and connecting a few graphical blocks. Visuino will automatically generate the necessary Arduino code.
Visuino contains a large set of components for:
  • Math functions
  • Comparators – Analog, Integer, Date/Time, and Color
  • Logic functions – OR, AND, XOR, NOT
  • Flip Flops – T, R-S, D, J-K
  • Switches – Analog, Integer, Date/Time, and Color
  • Generators – Clock, Pulse, Sine Wave, Triangular Wave, Rectangle, Random
  • Timers – periodic or single pulse
  • Counters – Up Down, and Directional
  • Motors – Stepper, DC or Servo
  • Displays – LCD, 7 Segment, touchscreen, matrix, Smart Pixels, and TV Out
  • Sensors – Temperature, Pressure, Weight, Distance, Compass, Accelerometer, Rotary Encoders
  • Remote controllers – Infrared, Servo, Wii or PS2 compatible
  • Date/Time components
  • Color components
  • PID controllers
  • Communication – Serial, RS 485, Wired and Wireless Wi-Fi Ethernet or GSM
  • and many more added daily...
Once the Arduino is programmed, Visuino offers easy way to connect to it over Serial and monitor multiple channels of data in a Terminal, Scope or Visual Instruments:
With the addition of the BPI:UNO32 support, Visuino brings all this this easy to use functionality to the BPI:UNO32 users. Furthermore the Visuino libraries add ESP32 functionality not otherwise available out of he box, including support for PWM Analog Output, Servo control, Play Tone and more.
How to use BPI-UNO32 with Visuino
Getting Started BPI-UNO32 with Visuino
Arduino
Arduino IDE Programing Function Define
Function IO
RGB_LED IO4
RGB_LED_POWER IO2
BUZZER IO25
BOTTON_A IO35
BOTTON_B IO27
TEMPERTURE_SENSOR IO34
MPU9250_AD0 IO0
Communication Protocol
SPI
MISO IO19
MOSI IO23
SCK IO23
SS IO5
I2C
SCL IO22
SDA IO21
Arduino IDE
  • Arduino IDE Compiled
Platform IO
  • Platform IO Compiled
microPyhton
资源
软件源代码
