Getting Started with M2M
Revision as of 05:23, 27 October 2018 by Sinovoip (talk | contribs)
BPI-M2M
  • 512MB DDR3 SDRAM
 * Using your USB-Serial Connect debug console on M2M
Compile code
After download code, execute "./build.sh" to compile it.
  • ./build.sh
Update your image
Update rootfs & kernal
After we succeed to the code, Bootloader, kernel, rootfs will be generated in "SD" directory, then how to update the image?
  • cd SD/bpi-m2m
Plug in your SD card to Ubuntu PC, then execute "fdisk -l" to check which /dev/sdX were generated by system
  • bpi-update -c bpi-m2m.conf -d /dev/sde
Update boot
  • cd 100MB
Execute "df -l" to check which /dev/sdX is "BPI-BOOT"
  • df -l
  • bpi-bootsel BPI-M2M-LCD7-8k.img.gz /dev/sd1
Make your own image
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
  • dhclient wlan0
NAS Application
1. Usb hub + sata to usb
  • HDD is supported
  • SSD is supported
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
