香蕉派 BPI-M2 Ultra
香蕉派 BPI-M2 Ultra 四核单板计算机采用全志 R40芯片开发。支持板载Wifi与蓝牙,支持SATA接口,可以直接接硬盘。并且板载8G eMMC ,可以选择SD卡启动或从eMMC flash 启动。
Banana PI BPI-M2 Ultra 兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统 和 全志Tina 系统.
Banana PI BPI-M2 Ultra硬件:全志R40 四核处理器,2GB LPDDR3内存,千兆以太网口,3USB 接口 流畅运行Android5.1。Banana PI BPI-M2 Ultra 体积如信用卡大小,与BPI-M3尺寸一样,GPIO兼容Raspberry PiB+并能运行其ROM Image。
- 全志R40/V40 Quad Core ARM Cortex A7 CPU
- 2GB DDR3 SDRAM.
- 8GB eMMC flahs onboard.
- SATA Interface.
- 2*USB 2.0
- MIPI DSI ingerface
- CSI camera interface
开始使用
- 如何烧录镜像并启动:快速上手 Banana pi SBC
- 开发快速入门 : 快速上手 香蕉派 BPI-M2 Ultra / BPI-M2 Berry
硬件接口图
File:BPI-M2 Ultra interface.jpg
| 香蕉派 BPI-M2 Ultra硬件规格书 | |||
| 主芯片 | Allwinner R40/V40 | ||
| CPU主控 | quad-core cortex -A7,the most power efficient CPU core ARM's ever development | ||
| SDRAM内存 | 2 GB DDR3 with 733MHz\(shared with GPU\) | ||
| SATA 硬盘接口 | suppoort SATA interface | ||
| GPIO定义 | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
| 有线网口 | 10/100/1000Mbps Ethernet \(Realtek RTL8211E/D\) | ||
| Wifi 无线 | WiFi 802.11 b/g/n \(AP 6212 module on board\) | ||
| 蓝牙支持 | BT4.0 | ||
| Flash存储 | MicroSD \(TF\) card,8GB eMMC onboard | ||
| 显示 | 4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4 | ||
| Audio outputs | HDMI, analog audio \(via 3.5 mm TRRS jack\) | ||
| Camera摄像头 | A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps | ||
| USB | 2 USB 2.0 host, 1 USB 2.0 OTG | ||
| 按键 | Reset button, Power button, U-boot button | ||
| Led 灯 | Power status Led and RJ45 Led | ||
| IR红外控制 | onboard IR receiver | ||
| DC 供电 | 5V/2A with micro USB port | ||
| 电池接口 | 3.7V lithium battery power support | ||
| 尺寸 | 85mmX56mm,same size as raspberry pi 3 | ||
| Weight | 40g | ||
GPIO PIN 定义
香蕉派BPI-M2 Ultra 支持40-pin GPIO 接口,定义兼容树莓派3. GPIO定义如下:
| 香蕉派BPI-M2 Ultra 40-pin GPIO 接口定义 | |||
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P04 | DCIN | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P11 | UART7-TX | PI20 | PWM2 |
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| CON1-P39 | GND | ||
CSI Camera 摄像头接口规格:
| BPI-M2 Ultra CSI 摄像头 GPIO 定义 | |||
| CN5-P01 | NC | ||
| CN5-P02 | GND | ||
| CN5-P04 | CSI0-AVDD | ||
| CN5-P10 | CSI0-DVDD | ||
| CN5-P11 | CSI0-DOVDD | ||
| CN5-P15 | GND | ||
| CN5-P16 | CSI0-D5 | PE9 | |
| CN5-P18 | CSI0-D4 | PE8 | |
| CN5-P19 | CSI0-D0 | PE4 | |
| CN5-P20 | CSI0-D3 | PE7 | |
| CN5-P21 | CSI0-D1 | PE5 | |
| CN5-P22 | CSI0-D2 | PE6 | |
| CN5-P23 | GND | ||
| CN5-P24 | CSI0-AFVCC | ||
MIPI屏显示接口规格
| 40 PIN GPIO of Banana pi BPI-M2 Ultra | |||
| CN6-P01 | VCC-3V3 | ||
| CN6-P02 | IPSOUT | ||
| CN6-P03 | VCC-3V3 | ||
| CN6-P04 | IPSOUT | ||
| CN6-P05 | GND | ||
| CN6-P06 | IPSOUT | ||
| CN6-P07 | GND | ||
| CN6-P08 | IPSOUT | ||
| CN6-P09 | NC | ||
| CN6-P10 | GND | ||
| CN6-P11 | NC | ||
| CN6-P12 | DSI-D0N | ||
| CN6-P13 | NC | ||
| CN6-P14 | DSI-D0P | ||
| CN6-P15 | NC | ||
| CN6-P16 | GND | ||
| CN6-P18 | DSI-D1N | ||
| CN6-P20 | DSI-D1P | ||
| CN6-P22 | GND | ||
| CN6-P24 | DSI-CKN | ||
| CN6-P25 | GND | ||
| CN6-P26 | DSI-CKP | ||
| CN6-P28 | GND | ||
| CN6-P30 | DSI-D2N | ||
| CN6-P32 | DSI-D2P | ||
| CN6-P33 | GND | ||
| CN6-P34 | GND | ||
| CN6-P35 | LCD-PWM | PB2 | |
| CN6-P36 | DSI-D3N | ||
| CN6-P37 | GND | ||
| CN6-P38 | DSI-D3P | ||
| CN6-P39 | NC | ||
| CN6-P40 | GND | ||
| CON4 Uart GPIO of Banana pi BPI-M2 Ultra | |||
| CON2 P03 | UART0-TXD | ||
| CON2 P02 | UART0-RXD | ||
| CON2 P01 | GND | ||
软件
软件开发
基本开发
- Banana Pi BPI-M2 Ultra / BPI-M2 Berry How to alter Uboot、Kernel
- How to boot from emmc with SD data
- How to rebuild bootloader BPI_M2U_720P-emmc.img.gz
资源
软件源代码
- Supports Banana Pi BPI-M2 Ultra (R40) (Kernel3.10)
- BPI official github:https://github.com/BPI-SINOVOIP/BPI-M2U-bsp
- other github for BPI-M2 Ultra /Berry : https://github.com/facat/BPI-M2U-bsp
- BPI-M2 Ultra/Berry TinaLinux github https://github.com/tinalinux/linux-3.10
开发参考文档
- Schematics BPI-M2 Ultra Schematics
- Allwinner R40/V40 datasheet
系统镜像
Android 6.0
- 2017-08-25 update
- HDMI-Version
- Baidu Cloud : MD5: c65fa4c20b8a6d2d05bfd32b090c3570
- LCD5-Version
- Baidu Cloud : MD5:f664e5fe0af20ebfc06ddc50bac1845b
- LCD7-Version
- baidu Cloud : MD5: 6cda3453d9524643c8f92fcdc8deb32f
3.10 kernel
- baidu cloud : https://pan.baidu.com/s/1cFHYGY1
- 2017-11-13 update
- baidu cloud : http://pan.baidu.com/s/1nvccOlz
- 2017-11-13 update debian-9-stretch-mate-desktop
- Google Drive : https://drive.google.com/file/d/0B_YnvHgh2rwjeTh4TmlnMGl5X3M/view?usp=sharing
- baidu cloud : http://pan.baidu.com/s/1c1LvS1y
- MD5: 0a1fad281c24902148b16276a79bac12
- 2017-11-13 update debian-9-stretch-lite
- Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjOWg1OW9heWZsYm8/view?usp=sharing
- baidu cloud: http://pan.baidu.com/s/1c3zxCy 13
- MD5: cff677aa94ca5345fc6e26379cfe4e95
- forum pthread : http://forum.banana-pi.org/t/bpi-m2-ultra-bpi-m2-berry-new-image-2017-08-28-debian-sd-emmc-img/3745/2
Rasbian
- 2017-05-25 update raspbian jessie
- Google Drive :https://drive.google.com/open?id=1Ntdh5tMyCjiAu8bBC9NC2ShEAYAAD0tD
- baidu cloud : https://pan.baidu.com/s/1civq4e
- MD5: 60e19ea9138d6841fa6852ece4727b0a
- forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m2-ultra-bpi-m2-berry-new-image-2017-05-25-raspbian-jessie-preview3-bpi-m2u-sd-emmc-img/3306
Tina IoT Linux
RPiTC v3 1.12
- 2017-11-28 updtae
Others
