香蕉派 BPI-M2 Magic
Revision as of 11:36, 25 October 2018 by Sinovoip (talk | contribs)
Overview:eMMC onboard
Overview:no eMMC onboard
香蕉派 BPI-M2 Magic (BPi-M2M) 是banana pi团队最新推出的一块高效率的四核物联网开发板 ,使用全志R16芯片与A33芯片设计。
File:A BPI-M2 Magic.jpg
BPI-M2 Magic 基于四核ARM Cortex-A7 CPU 和 Mali400MP2 GPU, It also includes a variety of peripherals, BPI-M2 Magic 板载 512兆 DDR3,8G EMMC存储falsh,包括MIPI DSI 摄 像头,LVDS屏接口,一个标准 USB2.0 一个OTG 接口,板载AP6212 802.11 b/g/n wifi & BT4.0 无线蓝牙模块.
注意: 1,BPI-M2 Magic 没有 HDMI 接口,显示接口只有屏. 2,没有有线网络接口,网络只支持无线
BPI-M2 Magic 能支持 Android 系统, 并支持像 Debian, Ubuntu linux, Raspberry Pi 系统和其他的Linux系统. 支持1080P高清视频,40 PIN GPIO 与Raspberry Pi B+兼容
  • Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
  • 512MB DDR3 SDRAM.
  • 8G eMMC flash
  • CSI camera interface
  • DSI display interface
开始使用
硬件接口示意图
Banana Pi M2 Magic 开发板
CPU Allwinner R16 ARM Cortex-A7 Quad-Core
Memory 512MB LPDDR3 (shared with GPU)
Storage On Board 8GB eMMC Flash, Micro SD-Card slot.
Network Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0
Video Output(s) MIPI Display Serial Interface (DSI) for raw LCD Panel
Audio Output(s) 3.5mm jack
USB ports USB 2.0 PORT (x1), USB OTG (x1)
Remote Not IR Receiver
LED灯 Power Status and 8P8C
供电 5 volt @2A via DC Power and/or Micro USB (OTG)
尺寸 & 重量 51x51mm, 48g
支持系统 Android and Linux
40 PIN GPIO of Banana pi BPI-M2 Magic
PIN number Default Function Function2:GPIO
CON1-P02 DCIN
CON1-P03 TWI1-SDA PH5
CON1-P04 DCIN
CON1-P05 TWI1-SCK PH4
CON1-P07 PWM1 PH1
CON1-P08 UART2-TX PB0
CON1-P10 UART2-RX PB1
CON1-P11 UART3\_TX PH6
CON1-P12 UART2-CTS PB3
CON1-P13 UART3\_RX PH7
CON1-P15 AP-PCM-DOUT PG12
CON1-P16 UART2-RTS PB2
CON1-P18 AP-PCM-CLK PG11
CON1-P19 SPI0\_MOSI PC0
CON1-P21 SPI0\_MISO PC1
CON1-P22 AP-PCM-SYNC PG10
CON1-P23 SPI0\_CLK PC2
CON1-P24 SPI0\_CS PC3
CON1-P26 AP-PCM-DIN PG13
CON1-P27 LVDS\_V0N PD19
CON1-P28 PL11-EINT11 PL11
CON1-P29 LVDS\_V0P PD18
CON1-P31 LVDS\_V1N PD21
CON1-P32 LVDS\_V2N PD23
CON1-P33 LVDS\_V1P PD20
CON1-P35 LVDS\_VCN PD25
CON1-P36 LVDS\_V2P PD22
CON1-P37 LVDS\_VCP PD24
CON1-P38 LVDS\_V3N PD27
CON1-P40 LVDS\_V3P PD26
CSI Camera pin define of Banana pi BPI-M2 Magic
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-AFVCC
    • DSI Pin Name**
MIPI DSI PIN define of Banana pi BPI-M2 Magic
CN2-P01 DSI-D0N
CN2-P02 DSI-D0P
CN2-P03 DSI-D1N
CN2-P04 DSI-D1P
CN2-P05 DSI-CKN
CN2-P06 DSI-CKP
CN2-P07 DSI-D2N
CN2-P08 DSI-D2P
CN2-P09 DSI-D3N
CN2-P10 DSI-D3P
CN2-P11 NC
CN2-P12 NC
CN2-P13 TP-SDA PH3
CN2-P14 TP-SCK PH2
CN2-P15 TP-INT PB5
CN2-P16 TP-RST PB6
CN2-P17 LCD-BL-EN PL4
CN2-P18 LCD-RST PL5
CN2-P19 LCD-PWR-EN PB7
CN2-P20 LCD-PWM PH0
CN2-P21 GND
CN2-P22 GND
CN2-P23 PS
CN2-P24 PS
Uart PIN define of Banana pi BPI-M2 Magic
CON3-P1 GND
CON3-P2 UART0-RX
CON3-P3 UART0-TX
Opnewrt
TinaLinux
About Tina-IoT Linux
BPI-M2 Magic R16 Tina Linux V1.0 have public,Come and try
Tina Linux development by Allwinner TinaTEAM, it base on OpenWrt,To build an embedded Linux distributions,The purpose of this release is to provide a quick learning and development is simple and convenient mass production Linux TurnKey solutions.
TinaLinux source code on github:
https://github.com/tinalinux/
Android 6.0 LCD5-Version
Kernel 3.4
  • Unbutu 16.04 2018-08-25 Image Link: This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4.
BPI-M2M Ubuntu 16.04 Features Map:http://wiki.banana-pi.org/M2M_Image_Map
LCD 7’-Version Google Drive : https://drive.google.com/open?id=14LH4NGAyfeCXhnKlzc75-K6p2gmO5RrM
LCD 7’-Version Baidu Drive : https://pan.baidu.com/s/17jiGC4fCSTfVKPWUgh-VXA
Forum pthread:http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-16-04-2018-08-25/6596
For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M2M
  • Unbutu 16.04 2018-01-04 Image Link:
Baidu Drive:https://pan.baidu.com/s/1kVKjxOF
Google Drive: https://drive.google.com/file/d/1GKwVO03Z5VHOaodVVyboLC-F7r_qyk7e/view?usp=sharing2
MD5: df72548c26cd42b8138f334f5b383f31
  • Unbutu 16.04 2017-10-23 Image Link:
Baidu Drive:http://pan.baidu.com/s/1hsGhxWS
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjU2xWQ3otX0JZb1E/view?usp=sharing
MD5: 23cd3f0891d8ad274984eea3f4981eab
Tina Linux for IoT
  • 2017-11-15 update : tina astar m2magic
more about Tina Linux Tina Linux
image name : 2017-11-15-tina_astar-m2magic_card0_burn_by_PhoenixCard.img
google downlad : https://drive.google.com/open?id=13iVMJJVY6i8GJjMjoAyk62IDW83MagDX
forum pthread: http://forum.banana-pi.org/t/bpi-m2-magic-new-image-2017-11-15-tina-astar-m2magic-card0-burn-by-phoenixcard/4184
