香蕉派 BPI-P2 Zero
BPI-P2 Zero介绍
香蕉派 BPI-P2 Zero 四核开源物联网开发板,采用全志H2+芯片设计,也可以直接用在H3,H5芯片方案。Banana Pi BPI-P2 Zero 是一种小巧的物联网开发板,板子尺寸只有65毫米52.5毫米。它使用四核 H2+处理器(也可以选择全志H3和H5),有512 MB内存。8 G eMMC,100兆网口,支持PoE功能,wifi无线支持,它支持linux和android操作系统。
- 512MB DDR 3 SDRAM.
- Mini HDMI.
- 100M LAN
- 8G eMMC flash onboard.
开始使用
- 快速入门 : Quick Start Banana pi SBC
- 如何使用BPI-P2 Zero开发 : Getting Start with M2 Zero
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core |
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 |
| IR | N/A | N/A | N/A |
| Weight | 30g | 15g | 9g |
| 40 PIN GPIO of Banana pi BPI-P2 Zero | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P04 | VCC-5V | ||
| CON2-P06 | GND | ||
| CON2-P09 | GND | ||
| CON2-P14 | GND | ||
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PC4 | PC4 | |
| CON2-P20 | GND | ||
| CON2-P25 | GND | ||
| CON2-P26 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P34 | GND | ||
| CON2-P39 | GND | ||
| 24 PIN CSI Camera connector of Banana pi BPI-P2 Zero | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | CSI0-DOVDD | ||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-DOVDD | ||
| jumper CON3 of Banana pi BPI-P2 Zero | |||
| CON3 P01 | GND | ||
PoE support
- Allwinner documents:
- Android 4.4 source code
- Linux source code
