Banana Pi Smart Router /Nas Comparison
Module
Banana Pi BPI-R1
Banana Pi BPI-R2
Banana Pi BPI-W2
Banana Pi BPI-R64
File:BPI-R64 1.JPG banana Pi BPI-R64
in progress
CPU
Allwinner A20,32 Bit Cortex™-A7 2-Core 1G
MTK MT7623N, 32 Bit Cortex™-A7 4-Core 1.3GHz
Realtek RTD1296 64 Bit quad-core ARM A53
MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
GPU
ARM® Mali400MP2
ARM® Mali450 MP4
Mali T820 MP3 GPU
N/A
SDRAM
1GB DDR3 (shared with GPU) 432Mhz
2GB DDR3 (shared with GPU) 1600Mhz
2GB DDR4 \(shared with GPU\)
1G DDR3
Storage
"SD Card up to 64GB (SDXC) 1 SATA up to 2TB "
"MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB "
"MicroSD (TF) card (UHS-1) 1 SATAIII 6Gbps EMMC 4.5 8GB "
Network
4x Gigabit LAN 1x Gigabit WAN
4x Gigabit LAN 1x Gigabit WAN (MT7530)
1x Gigabit LAN 1x Gigabit WAN
WIFI
802.11b/g/n (RTL8192CU)
"802.11a/b/g/n & BT4.1 (MT6625L) 802.11ac moudle Wi-Fi 4x4 (MT7615 option)"
N/A
built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip and MTK7615 4x4ac wifi on board
Vidio In
CSI input for video cameras
NA
HDMI in
N/A
Video Out
HDMI/LVDS/RGB
HDMI/MIPI
HDMI/ MIPI DP
N/A
Audio Output
3.5 mm Jack and HDMI out
HDMI out & I2S
HDMI out, I2S audio,Audio micro out
N/A
Audio In
Microphone
N/A
2 MIC in and HDMI in
N/A
USB 2.0
2 USB 2.0 ports, 1 OTG microUSB port
1 USB 2.0 OTG
2x USB 2.0 OTG :1 with standard USB port , 1 define with PIN
N/A
USB 3.0
N/A
2xUSB 3.0
1xUSB 3.0
1xUSB 3.0
HDMI in
N/A
N/A
1 HDMI in
N/A
TYPE C
N/A
N/A
1x TYPE C
N/A
Mini DP
N/A
N/A
1x Mini DP
N/A
PCIE
N/A
1* mini PCIE,1*pcie with 14 PIN define
1xM.2 KEY B : USB 2.0 for 4G with Micro SIM card slot ;2xM.2 KEY E:1 with PCIE 2.0/USB 2.0,1 with 1 pcie 1.1/SDIO/USB 2.0 interface
1* mini PCIE
GPIO 40-PIN
GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground.
40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
Power Source
5 volt via MicroUSB and/or MicroUSB (OTG)
12 volt via DC In
12 volt via DC In
12 volt via DC In
Buttons
Reset button Power button, Uboot button
Recovery buton
LED
Power key and RJ45
Power key and RJ45
Power key and RJ45
Power status Led and RJ45 Led
Remote
IR reciever
IR reciever
IR reciever
N/A
Board Size
120mm ×100mm
120mm ×100mm
120mm ×100mm
120mm ×100mm
Weight
60g
60g
60g
100g
OS
Android and Linux OS OpenWRT
Linux OS OpenWRT
