Getting Started with M1
Revision as of 02:28, 11 October 2018 by JackZengWiki (talk | contribs)
BPI-M1
File:BPI-m1 respbian.png
Overview: BPI-M1 respbian linux
File:BPI-m1 debian.jpg
Overview: BPI-M1 debian linux
File:BPI-m1 ubutnu.jpg
Overview: BPI-M1 ubuntu linux
  The Banana Pi M1 is our first product in our goal of creating an open source devlopment board community. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project
  • Dual-core 1.0GHz CPU
  • 1 GB DDR3 memeory
  • Mali-400 MP2 with Open GL ES 2.0/1.1
Development For Android
Load your first image on M1
 Ex:
How to buld M1 Bsp code
 * Prepare a PC which runs ubuntu
 * Install Docker-ce on your PC,https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-ce
 * After install Docker, execute "docker pull sinovoip/bpi-build-android:a20_01", to pull image
 * Then you pulled image, execute "docker run --privileged -d -p 2223:22 -v /media:/media sinovoip/bpi-build-android:a20_01"
 * "ssh -p 2223 [email protected] #default passwd is root"
 * Execute "git clone https://github.com/BPI-SINOVOIP/BPI-M1-bsp.git" on your ubuntu terminal
 * Execute "./build.sh" to build M1 bsp code
 * After built, open a new terminal, execute "docker cp xxxxx(your container id):xxxxx(your project path) xxxxx(your pc path)"
Development For Linux
Let's get start to develop on BPI-M1, see amazing things happen.
 * Using your USB-Serial Connect debug console on M1
 * Here is the example link:
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M1, and press power button setup M1
Update your image
  * execute “bpi-tools”, to update your bpi tools;
  * execute “bpi-update -c bpi-m1.conf”, to download new driver to update your image
  * execute “file *.tgz”, to check download files’ type is compressed data
  * execute “bpi-bootsel”, you will see the bootloader path, “/usr/lib/u-boot/bananapi/u-boot-2018.01/u-boot-2018.01-bpi-m1-8k.img.gz”
  * execute “bpi-bootsel /usr/lib/u-boot/bananapi/u-boot-2018.01/u-boot-2018.01-bpi-m1-8k.img.gz”, to update your bootloader
  * reboot
