BPI-Bit
Revision as of 01:53, 15 October 2018 by Sinovoip (talk | contribs) (Undo revision 4640 by Sinovoip (talk))
BPI:bit介绍
Overview: BPI:bit
BPI-UNO32 with ESP32 design
Overview: BPI:bit
BPI:bit gpio expansion board
BPI:bit 主要功能介绍
  • Buzzer: GPIO25
硬件简介
硬件接口
GPIO PIN针定义
P3 ADC2_CH4 GPIO13
P0 ADC2_CH8 DAC_1 GPIO25
P4 ADC2_CH3 GPIO16
P5 ADC1_CH7 GPIO35
P6 ADC2_CH5 GPIO12
P7 ADC2_CH6 GPIO14
P1 ADC1_CH4 GPIO32
P8 GPIO16
P9 GPIO17
P10 ADC2_CH9 DAC_2 GPIO26
P11 ADC2_CH7 GPIO27
P12 ADC2_CH2 GPIO02
P2 ADC1_CH5 GPIO33
P13 GPIO18 SPI_SS
P14 GPIO19 SPI_SCK
P15 GPIO23 SPI_MISO
P16 GPIO05 SPI_MOSI
3V3 POWER:3V3
3V3 POWER:3V3
3V3 POWER:3V3
P19 GPIO22 I2C_SCL
P20 GPIO21 I2C_SDA
GND GROUND
GND GROUND
GND GROUND
5*5 25全彩LED灯
25 5*5 LED list of BPI:bit
20 15 10 5 0
21 16 11 6 1
22 17 12 7 2
23 18 13 8 3
24 19 14 9 4
MPU9250 9-axis sensor
BPI-BIT MPU9250 Library and how to : https://github.com/BPI-STEAM/MPU9250
BPI:bit 供电
BPI:bit 与 micro:bit 比较表
bpi:bit VS micro:bit
Module bpi:bit micro:bit
RAM 520 KB 16 KB
ROM 448 KB Unkown
Flash 4096 KB 256 KB
WIFI 802.11 b/g/n/e/i N/A
Buzzer 1x Buzzer N/A
Size 5*5 cm 5*4 cm
软件
BPI:bit 软件开发规划表与支持应用:
Webduino 软件支持
What is Webduino
BPI:bit Webduino 开发
如何使用 :Use BPI:bit with webduino
webduino 参考教程
  • BPI:bit Through the photosensitive resistors built into Webduino Bit on the left and right sides, it is easy to determine which side the gesture comes from
  • Using Webduino Bit nine shaft sensor "attitude Angle" + full color dot matrix, simple implementation ~ ^_^ interesting effects
Arduino 开发
测试例程
MicroPyhton 开发
Scratch 支持与开发
Github
Useful links
