BPI-Bit
BPI:bit介绍
BPI:bit 主要功能介绍
- Buzzer: GPIO25
硬件简介
硬件接口
GPIO PIN针定义
P3 | ADC2_CH4 | GPIO13 | |||
P4 | ADC2_CH3 | GPIO16 | |||
P5 | ADC1_CH7 | GPIO35 | |||
P6 | ADC2_CH5 | GPIO12 | |||
P7 | ADC2_CH6 | GPIO14 | |||
P1 | ADC1_CH4 | GPIO32 | |||
P8 | GPIO16 | ||||
P9 | GPIO17 | ||||
P11 | ADC2_CH7 | GPIO27 | |||
P12 | ADC2_CH2 | GPIO02 | |||
P2 | ADC1_CH5 | GPIO33 | |||
P13 | GPIO18 | SPI_SS | |||
P14 | GPIO19 | SPI_SCK | |||
P15 | GPIO23 | SPI_MISO | |||
P16 | GPIO05 | SPI_MOSI | |||
3V3 | POWER:3V3 | ||||
P19 | GPIO22 | I2C_SCL | |||
P20 | GPIO21 | I2C_SDA | |||
GND | GROUND | ||||
GND | GROUND | ||||
GND | GROUND |
5*5 25全彩LED灯
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
MPU9250 9轴传感器
BPI:bit 供电
BPI:bit 与 micro:bit 比较表
RAM | 520 KB | 16 KB | |||||
ROM | 448 KB | Unkown | |||||
Size | 5*5 cm | 5*4 cm |
软件
BPI:bit 软件开发规划表:
Webduino
What is Webduino
BPI:bit for Webduino
How to :Use BPI:bit with webduino
Arduino
Examples
MicroPyhton
Scratch
Github
Useful links
- BPI:bit schematic diagram
- BPI:bit user manual
- BPI:bit dxf file
- ESP32 datasheet
- Espressif ESP32 Resources
- MPU9250 datasheet
- More others
- Webduino official website
- Webduino website in China
- Facebook group
- Maker Pro
webduino See sample
