Lighting the RGB LED
Revision as of 07:49, 1 October 2018 by Jh (talk | contribs) (How to lighting the RGB LED)
Install Library
  1. Install library from github:
  • Librarys:[NeoPixel_Bus] from Makuna
  • Download libraries and put it in the libraries folder in the installation directory of the Arduino IDE
  1. Install Library by Manage Libraries:
Programe Code
  • Open Arduino IDE
click 'file'->'Example'->'NeoPixel Bus'->'simple' to open the example
  • We need to change some code,Find the code below in the code
const uint16_t PixelCount = 4; // this example assumes 4 pixels, making it smaller will cause a failure const uint8_t PixelPin = 2; // make sure to set this to the correct pin, ignored for Esp8266
  • change to
const uint16_t PixelCount = 25; // this example assumes 4 pixels, making it smaller will cause a failure const uint8_t PixelPin = 4; // make sure to set this to the correct pin, ignored for Esp8266
  • Then add the following code to void setup()
  1. define LED_POWER 2
pinMode(LED_POWER, OUTPUT); digitalWrite(LED_POWER, HIGH);
  • Compile this program
And download it(Set the serial port and board)
