Banana Pi BPI-M3
  • Allwinner A83T Octa-core 1.8GHz Powerful CPU.
  • 2 GB LPDDR3 memory.
  • 8 GB eMMC storage.
  • HDMI out
  • IR control
  • WiFi & Bluetooth onboard.
  • MIPI DSI ingerface
  • CSI camera interface
Banana Pi BPI-M3
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO define of Banana pi BPI-M3
Default Function Function2:GPIO Function3
CON1-P02 DCIN
CON1-P03 TWI2-SDA PH5-EINT5
CON1-P04 DCIN
CON1-P05 PH4-EINT4
CON1-P07 S-PWM PL10-S-EINT10
CON1-P08 UART2-TX PB0-EINT0
CON1-P10 UART2-RX PB1-EINT1
CON1-P11 PC4 PC4
CON1-P12 UART2-CTS PB3-EINT3
CON1-P13 PC7 PC7
CON1-P15 PC17 PC17
CON1-P16 UART2-RTS PB2-EINT2
CON1-P18 PL8-ENT8 PL8-S-ENT8
CON1-P19 SPI0_MOSI PC0
CON1-P21 SPI0_MISO PC1
CON1-P23 SPI0_CLK PC2
CON1-P24 SPI0_CS PC3
CON1-P27 TWI1-SDA PH3-EINT3
CON1-P28 TWI1-SCK PH2-EINT2
CON1-P29 PC18 PC18
CON1-P36 PE5 PE5
CON1-P37 PE4 PE4
CON1-P38 OWA-DOUT PE18
CON1-P40 PE19 PE19
    • CSI Camera Connector specification:**
CSI Camera Connector:
Default Function| Function2:GPIO|
IPSOUT AFVCC IPSOUT IOVDD GND GND CSI2-D3N AVDD-CSI CSI2-D3P DVDD-CSI-R GND NC CSI2-D2N CSI-RST-R| PE16| CSI2-D2P CSI-STBY-R| PE17| GND CSI-PCLK| PE0| CSI2-CKN CSI-MCLK| PE1| CSI2-CKP CSI-HSYNC| PE2| GND CSI-VSYNC| PE3| CSI2-D1N| CSI-D9| PE13| CSI2-D1P CSI-D8| PE12| GND CSI-D7| PE11| CSI2-D0N CSI-D6| PE10| CSI2-D0P CSI-D5| PE9| GND CSI-D4| PE8| CSI-SCK| PE14| CSI-D3| PE7| CSI-SDA| PE15| CSI-D2| PE6|
    • Display specification**
VCC-MIPI IPSOUT VCC-MIPI IPSOUT GND IPSOUT GND IPSOUT NC GND NC DSI-D0N NC DSI-D0P NC GND TWI0-SDA| PH1-EINT1| DSI-D1N TWI0-SCK| PH0-EINT0| DSI-D1P TP-INT| PL7-S-EINT7| GND TP-RST| PL6-S-EINT6| DSI-CKN GND DSI-CKP LCD-BL-EN| PD29| GND LCD-RST| PD26| DSI-D2N LCD-PWR-EN| PD27| DSI-D2P GND GND LCD-PWM| PD28| DSI-D3N GND DSI-D3P AP-RESET# GND
    • UART specification:**
Default Function| GPIO|
UART0-TXD| PB9| UART0-RXD| PB10| GND
Opnewrt
TinaLinux
Release
