BPI-Bit
- Buzzer: GPIO25
Description
Interface
Edge interface
PIN definitions
| P8 | GPIO16 | ||||
| P9 | GPIO17 | ||||
| P13 | GPIO18 | SPI_SS | |||
| 3V3 | POWER:3V3 | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
5*5 LED list
| 20 | 15 | 10 | 5 | 0 |
| 21 | 16 | 11 | 6 | 1 |
| 22 | 17 | 12 | 7 | 2 |
| 23 | 18 | 13 | 8 | 3 |
| 24 | 19 | 14 | 9 | 4 |
MPU9250 9-axis sensor
The 9-axis is the combination of 3 separate triple axis sensors. For more detailed information of this chip, click here MPU 9250 datasheet to view the datasheet.
BPI:bit power
BPI:bit VS micro:bit
BPI:bit planning programming:
Webduino
What is Webduino
BPI:bit for Webduino
How to :Use BPI:bit with webduino
Arduino
Examples
MPU9250 sample code
- code update to github : MPU9250 exmaple
MicroPyhton
Scratch
Examples
MPU9250 sample code
Github
- Webduino github: https://github.com/webduinoio
- bpi:bit github: https://github.com/BPI-STEAM
Useful links
- BPI:bit dxf file : http://forum.banana-pi.org/uploads/default/original/2X/0/0b86ccaeb565cdeef093164fd1ff837727ca2887.rar
- ESP32 Arduino Tutorial Overview : https://www.dfrobot.com/blog-964.html
- Espressif ESP32 Resources :https://www.espressif.com/products/hardware/esp32/resources
- Espressif ESP-IDF Programming Guide : https://esp-idf.readthedocs.io/en/latest/
- Webduino official website : http://webuino.io
- Webduino website in China : http://www.webduino.com.cn/site/en/
- Facebook group
webduino See sample
