Lighting the RGB LED
How to lighting the RGB LED
Install Library
- Install library from github:
- Librarys:[Adafruit_NeoPixel] from Adafruit
- Download libraries and put it in the libraries folder in the installation directory of the Arduino IDE
- Install Library by Manage Libraries:
Programe Code
- Open Arduino IDE
click 'file'->'Example'->'Adafruit NeoPixel'->'simple' to open the example
- We need to change some code,Find the code below in the code
#define PIN 6 #define NUMPIXELS 16
- change to
#define PIN 4 #define NUMPIXELS 25 #define LED_POWER 2
- Then add the following code to void setup()
pinMode(LED_POWER, OUTPUT); digitalWrite(LED_POWER, HIGH);
- Compile this program
And download it(Set the serial port and board)
