Getting Started with R2
Revision as of 23:09, 5 September 2018 by 14.152.101.61 (talk) (Ubuntu On Emmc)
Read more: Banana Pi BPI-R2
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • 1x Mini PCIE interface
  • 2x SATA interface
BPI-R2 SATA interface
  • Note:
Load your first image on R2
 * apt-get install pv
Ubuntu On SD Card
Ubuntu On Emmc
 1. If you want to install Ubuntu on EMMC, follow these steps:
 * Program ubuntu image to SD card
 * Install this SD to R2 board and boot from SD
 * Enter the Uboot prompt, and run command emmc pconf 48 to change Partition config of EMMC
 * And then run command reset, let it boot to OS
 * Enter the system with username pi or root
 * Run command to enable /dev/mmcblk1boot0 write mode
   echo 0 > /sys/block/mmcblk1boot0/force_ro
 * To write preloader to EMMC by running command:
   wget https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
   bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0
 * where BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz is the preloader for emmc, wget https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz will download it from link:https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
 * To copy ubuntu image to EMMC:
   unzip -p <XXX.img.zip> | pv | dd of=<device> bs=10M status=noxfer
   or
   bpi-copy  <XXX.img.zip> /dev/mmcblk1
 * XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html
 * power off
 * remove SD & power on
OpenWrt
     you will find two images:
     * mtk-bpi-r2-EMMC.img
     * mtk-bpi-r2-SD.img
Network-Configuration
GPIO
PWM Control
Develop 4G module with R2
Gets more info from here:
Using 4G module with BananaPi
WiFi and Ap mode on R2 Ubuntu
  • wmt_loader (ignore errors)
  • ip link set wlan0 up
  • dhclient wlan0
AP mode
  • echo A >/dev/wmtWifi
 interface=ap0
 bridge=br0
 ssid=test_r2
 driver=nl80211
 country_code=US
 hw_mode=b
 channel=1
 max_num_sta=5
 wpa=2
 auth_algs=1
 rsn_pairwise=CCMP
 wpa_key_mgmt=WPA-PSK
 wpa_passphrase=ledetest
 logger_stdout=-1
 logger_stdout_level=2
  • And a bridge
  • brctl addbr br0
  • brctl addif br0 ap0
  • brctl addif br wan
AP mode
1. Make a bash script
  • vim setup.sh
 #!/bin/ash
 wmt_loader &
 sheep 3
 sleep 5
 echo A > /dev/wmtWifi &
 sleep 5
 hostapd -d hostapd.conf
2. Create your hostapd.conf
  • vim hostapd.conf
 interface=ap0
 bridge=br-lan
 ssid=BPI_R2
 driver=nl80211
 country_code=CN
 hw_mode=g
 channel=1
 max_num_sta=5
 wpa=2
 auth_algs=1
 rsn_pairwise=CCMP
 logger_stdout=-1
3. Make it run
  • ./setup.sh
  • vim /etc/rc.local
 cd /root/
 sleep 6
 ./setup.sh &
Make your own image
Reference Link
