Getting Started with M2M
BPI-M2M
  • 512MB DDR3 SDRAM
 * Using your USB-Serial Connect debug console on M2M
  • Execute "bluetoothctl"
  • Execute these commands:
File:M2M BT.png
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
