BPI-BT BLE 4.2 control module
BPI-BT BLE 4.2 control module is a kind of maker product of wireless bluetooth intelligent control. It supports bluetooth BLE4.2 protocol. Through the connection of smart phone BLE bluetooth, it can control LED lights, N20 motor, micro-steering machine, relay, electromagnet and other low-voltage devices, which facilitates the makers to realize their creativity.
hardware spec
Hardware Specification of BPI-BT BLE 4.2 control module
name parameter explain
operating frequency 2.4G
operating voltage 3.7~6V It is recommended to use the 2A battery pack, or 4 section 5 dry batteries.
operating temperature -40℃ - 80℃
transmission range 60m Open field data.Indoor transmission will be reduced.
bluetooth BLE 4.2
size 32mm x 35mm x 14mm 3 M3 fixed holes are left, and the hole spacing is compatible with lego brick hole spacing, which is convenient to be fixed with M3 flat head screw.
