Banana Pi BPI-M1
The BPI-M1 is our first product in our goal of creating an open source devlopment board community. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
- 1 GB DDR3 memory.
- 1x SATA interface.
- 1x Gigabit LAN
- 1X MIC
- AV vide out
- CSI camera interface
- DSI display interface
- 26 PIN gpio
| Banana Pi BPI-M1 | |
| CPU | A20 ARM Cortex -A7 Dual-Core |
| GPU | ARM Mali 400 MP2; Complies with OpenGL ES 2.0/1.1 |
| Memory | 1GB DDR3 |
| Network | 10/100/1000 Ethernet 8P8C (1000BASE-T) |
| Video Input | A CSI input connector allows for the connection of a designed camera module |
| Video Outputs | HDMI, CVBS, LVDS/RGB |
| Audio Outputs | 3.5mm jack and HDMI |
| Power Source | 5 volts DC via Micro USB or GPIO |
| USB 2.0 ports | 2 (direct from Allwinner A20 chip) |
| GPIO | GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND |
| LED | Power Key & 8P8C |
| Storage | SATA 2.0, |
Banana Pi BPI-M1 has a 40-pin GPIO header that matches that of the Model Raspberry Pi 3. Following is the Banana Pi GPIO Pinout:
