Banana Pi BPI-R64
Revision as of 13:41, 30 July 2018 by Sinovoip (talk | contribs) (Release)
File:BPI-R64 1.JPG
Overview:banana Pi BPI-R64
File:BPI-R64 2.JPG
BPI-R64 with MTK7622 64 bit
BPI-R64 with POE function support
File:BPI-R64 POE 1.jpg
BPI-R64 with POE module (12V 3A)
MTK MT7622
  • 1G DDR3 SDRAM
  • MTK7615 4x4ac wifi on board
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
Hardware Revision
SDRAM 1 GB DDR3
SATA suppoort 1 SATA interface
USB 1 USB 3.0 host
Buttons Reset button
IR onboard IR receiver
DC Power 5V/2A with DC in
Sizes 148 mm × 100.5mm
Weight 100g
PoE support
we design PoE function for BPI-R64 ,so easy to add PoE module to support PoE function,PoE modue can support 12V/3A to power BPI-R64
BPI-R64 GPIO Pin define
Release
