Banana Pi BPI-P2 Zero
Revision as of 18:48, 1 August 2018 by Sinovoip (talk | contribs) (Created page with "=Introduction= thumb|Overview zero with Allwinner H2+ chip thumb|Overview zero with Allwinner H3 chip File:BPI-M2_zer...")
- 512MB DDR 3 SDRAM.
- Mini HDMI.
| HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W | |||
| Module | Banana Pi BPI-M2 Zero | Raspberry Pi Zero W | |
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core | |
| GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | VideoCore IV | |
| Memory \(SDRAM\) | 512M DDR3(shared with GPU) | 512 MB DDR2 | |
| Onboard Storage | TF card \(Max. 64GB\) | TF card \(Max. 64GB\) | |
| Onboard Network | NOPE (but can extension with PIN define) | NOPE | |
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 | |
| Video decoding | 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 | 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder | |
| Video input | A CSI input connector Camera | CSI camera connector | |
| Video Outputs | mini HDMI 1.4,1080P@30fps, DHCP | Mini HDMI and USB On-The-Go ports | |
| Audio Output | Mini HDMI | Mini HDMI | |
| Power Source | Micro USB with 5V/2A | 5V/2A | |
| USB 2.0 Ports | one USB 2.0 OTG | one USB 2.0 OTG | |
| Buttons | Power Button, Reset Button | Composite video and reset headers | |
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | 40 PIN | |
| uart GPIO\(1x3\) pin | UART, ground | UART | |
| LED | Power led & Status led | Power Status LED | |
| IR | N/A | N/A | |
| Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | Linux | |
| Product size | 65mm × 30mm | 65mm x 30mm | |
| Weight | 15g | 9G | |
