Banana Pi BPI-R64
MTK MT7622
- 1G DDR3 SDRAM
- MTK7615 4x4 AC wifi on board
- support 1 SATA interface
- (1) USB 3.0
- POE function support
Hardware Revision
HardWare Specification of Banana pi BPI-M2 Ultra | |||
SDRAM | 1 GB DDR3 | ||
SATA | suppoort 1 SATA interface | ||
On board Network | 5 10/100/1000Mbps Ethernet | ||
Wifi Module | MTK7615 AC wifi on board | ||
USB | 1 USB 3.0 host | ||
Buttons | Reset button | ||
IR | onboard IR receiver | ||
DC Power | 5V/2A with DC in | ||
Sizes | 148 mm × 100.5mm | ||
Weight | 100g |
PoE support
we design PoE function for BPI-R64 ,so easy to add PoE module to support PoE function,PoE modue can support 12V/3A to power BPI-R64
BPI-R64 GPIO Pin define
