Getting Started with R2
Revision as of 23:03, 6 May 2018 by JackZengWiki (talk | contribs) (Wifi and Ap mode on R2)
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface
  • SATA interface
 1.Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
 2.Using your USB-Serial Connect debug console on R2
Load your first image on R2
 * apt-get install pv
Build your own image on R2
 5. If you want to install Ubuntu on EMMC, follow these steps:
 * Program ubuntu image to SD card
 * Install this SD to R2 board and boot from SD
 * Enter the Uboot prompt, and run command emmc pconf 48 to change Partition config of EMMC
 * And then run command reset, let it boot to OS
 * Enter the system with username pi or root
 * Run command
   echo 0 > /sys/block/mmcblk1boot0/force_ro  to enable /dev/mmcblk1boot0 write mode`
 * To write preloader to EMMC by running command:
   "bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0" where BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz is the preloader for emmc, please download it from link:https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
 * To copy ubuntu image to EMMC:
   unzip -p <XXX.img.zip> | pv | dd of=<device> bs=10M status=noxfer
   or
   bpi-copy  <XXX.img.zip> <device> where the XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html 40, and where should be /dev/mmcblk1.
 * power off
 * remove SD & power on
OpenWrt
     you will find two images:
     * mtk-bpi-r2-EMMC.img
     * mtk-bpi-r2-SD.img
 (2) Write image to TF card, execute "bpi-copy if=mtk-bpi-r2-SD.img of=/dev/sdX"
GPIO
PWM Control
  • echo 4 >/sys/class/pwm/pwmchip0/export
  • echo 200000 >/sys/class/pwm/pwmchip0/pwm4/period
  • echo 100000 >/sys/class/pwm/pwmchip0/pwm4/duty_cycle
  • echo 1 >/sys/class/pwm/pwmchip0/pwm4/enable
Develop 4G module with R2
Gets more info from here:
WiFi and Ap mode on R2
  • wmt_loader (ignore errors)
  • ip link set wlan0 up
  • dhclient wlan0
Make your own image
Reference Link
