Banana Pi BPI-R64
Revision as of 08:40, 27 July 2018 by Sinovoip (talk | contribs) (Summary)
File:BPI-R64 1.JPG
Overview:banana Pi BPI-R64
File:BPI-R64 2.JPG
BPI-R64 with MTK7622 64 bit
The Banana Pi R64 is a router based development board, which can run on a variety of open source operating systems including OpenWrt, Android,Linux. It has 4 Gigabit LAN ports, 1 Gigabit WAN, and AC wifi AP function. use 64 bit chip design
  • 1G DDR3 SDRAM
  • MTK7615 AC wifi on board
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
Hardware Revision
SDRAM 1 GB DDR3
SATA suppoort 1 SATA interface
Wifi Module MTK7615 AC wifi on board
USB 1 USB 3.0 host
Buttons Reset button
IR onboard IR receiver
DC Power 5V/2A with DC in
Sizes 148 mm × 100.5mm
Weight 100g
BPI-R64 GPIO Pin define
Release
Ubuntu with kernel 4.4
Ubuntu with kernel 4.14
OpenWrt(LEDE)
Centos 7
