Successful case
4G Multiple polymerization
this is base on BPI-R2, with 4 4G module desin .
4G Multiple polymerization server
4G Multiple polymerization terminal
MultiQB
pcba inside:
Case design:
Hardware Specification
- SIZE: two-deck, 88x88 mm
- Memory: 1 GB DDR3
- USB: USB Host 2.0 x 1
- AUDIO Input: Microphone x 1
- VIDEO Outputs: HDMI out x 1
- IR Receiver: x1
KANO Pixel Kit
eBlocker
PCBA inside:
4G Industrial safety tablets
PCBA inside:
MTK MT6737 4G watch
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
