Getting Started with M2 Zero
Overview: BPI-M2Z raspbian
BPI-M2 Zero
  • 512MB SDRAM.
  • Mini HDMI.
Load your first image on M2 Zero
 * Here is the example: http://forum.banana-pi.org/t/bananapi-bpi-m2z-h2-new-image-raspbian-ubuntu-release-2018-07-09/6221
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M2 Zero, and press power button setup M2 Zero
How to create an image
  • Boot your SD card with M2 Zero, after M2 Zero finish starting, copy your files and config your system, then poweroff M2 Zero. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2z.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2 Zero console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2 Zero and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2 ZeroP OTG
  • If yes, we could execute "adb shell" to connect M2 Zero by adb now
USB Ethernet
  • Prepare a USB to OTG wire, usb ethernet adapter
  • Use iperf3 to test network
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
WringPi
