Banana Pi BPI-M64
Revision as of 00:46, 30 May 2018 by Sinovoip (talk | contribs) (Getting Start)
Overview:Allwinner A64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
  • Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2 GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
  • MIPI LCD interface
  • Camera interface
Banana Pi M64
CPU Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU
GPU Dual core Mali 400 MP2 GPU
SDROM 2 GB LPDDR3 (shared with GPU)
Flash 8 G eMMC flash (option 16/32/64G)
Micro SD slot 8-64G MicroSD \(TF\) card
WIFI*BT Wi-Fi 802.11 b/g/n + Bluetooth BT4.0
Video Output(s) high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO of Banana pi BPI-M64
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI1-SDA PH3
CON2-P04 VCC-5V
CON2-P05 TWI1-SCK PH2
CON2-P06 GND
CON2-P07 PH6 PH6
CON2-P08 UART2-TX PB0
CON2-P09 GND
CON2-P10 UART2-RX PB1
CON2-P11 PH7 PH7
CON2-P12 UART2-CTS PB3
CON2-P13 DMIC-CLK PH10
CON2-P14 GND
CON2-P15 DMIC-DIN PH11
CON2-P16 UART2-RTS PB2
CON2-P17 VCC-3V3
CON2-P18 PD4 PD4
CON2-P19 SPI1-MOSI PD2 UART4-TX
CON2-P20 GND
CON2-P21 SPI1-MISO PD3 UART4-RX
CON2-P22 PC0 PC0
CON2-P23 SPI1-CLK PD1 UART3-RX
CON2-P24 SPI1-CS PD0 UART3-TX
CON2-P25 GND
CON2-P26 PC2 PC2
CON2-P27 PC4 PC4
CON2-P28 PC3 PC3
CON2-P29 PC7 PC7
CON2-P30 GND
CON2-P31 PCM0-BCLK PB5
CON2-P32 PCM0-DIN PB7
CON2-P33 PCM0-SYNC PB4
CON2-P34 GND
CON2-P35 PCM0-DOUT PB6
CON2-P36 PL9 PL9
CON2-P37 PL12 PL12
CON2-P38 PL7 PL7
CON2-P39 GND
CON2-P40 PL8 PL8
CSI camer PIN define of Banana pi BPI-M64
CN5-P01 NC
CN5-P02 GND
CN5-P03 CSI0-SDA PE13
CN5-P04 CSI0-AVDD
CN5-P05 CSI0-SCK PE12
CN5-P06 CSI0-Reset PE16
CN5-P07 CSI0-VSYNC
CN5-P08 CSI0-PWDN PE17
CN5-P09 CSI0-HSYNC PE2
CN5-P10 CSI0-DVDD
CN5-P11 CSI0-DOVDD
CN5-P12 CSI0-D7 PE11
CN5-P13 CSI0-MCLK PE1
CN5-P14 CSI0-D6 PE10
CN5-P15 GND
CN5-P16 CSI0-D5 PE9
CN5-P17 CSI0-PCLK PE0
CN5-P18 CSI0-D4 PE8
CN5-P19 CSI0-D0 PE4
CN5-P20 CSI0-D3 PE7
CN5-P21 CSI0-D1 PE5
CN5-P22 CSI0-D2 PE6
CN5-P23 GND
CN5-P24 CSI0-AFVCC
MIPI DSI display PIN define of Banana pi BPI-M64
CN6-P01 VCC
CN6-P02 IPSOUT
CN6-P03 VCC
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PH1
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PH0
CN6-P20 DSI-D1P
CN6-P21 CTP-INT PH4
CN6-P22 GND
CN6-P23 CTP-RST PH8
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PD5
CN6-P28 GND
CN6-P29 LCD-RST PD6
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PD7
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PL10
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
Uart PIN define of Banana pi BPI-M2+
CON2 P03 UART0-TXD PB8
CON2 P02 UART0-RXD PB9
CON2 P01 GND
Win 10 IoT
banana pi BPI-M64 IOT certifying pass by Microsoft:windows 10 iot core
link: https://azure.microsoft.com/en-us/documentation/articles/iot-hub-tested-configurations/
get start:
https://github.com/Azure/azure-iot-sdks/blob/master/doc/get_started/windows10-iot-core-banana-pi-bpi-m64-csharp.md
test on BPI-M64
discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m64-iot-certifying-pass-by-microsoft-windows-10-iot-core/2090
Windows 10 IoT Core for BPI-M64 Release Note
This document describes how to build AllWinner UEFI Firmware and bring a AllWinner dev board up with it. The AllWinner UEFI Firmware, as the major boot system for AllWinner-Windows platform, is based on the EDK2 framework which is open-source and with some AllWinner platform software packages injected.
Some updates:
1. Update the OS version to build v.10.0.15063.0 \(Creators Update\)
2. New page style of Device Portal, visit [1](https://deviceipaddr:8080) to check it
3. Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
4. Support on-screen keyboard, need to be enabled in Device Portal
5. Enable 100M Ethernet and fix some bugs
6. Support built-in UART bus in A64 SoC\(not built in the ffu, later provide driver binary and deployment helper\)
7. Support built-in IR module in A64 SoC\(not built in the ffu, later provide source code and dev doc for developers in community\)
Known Issues:
Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable : Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
An PnP bug in audio device may cause a blue screen when acting software shutdown
Ethernet device may not start with problem code 12 at the first time to bring up
And another bomb! I uploaded core driver binaries and packaging toolchains on GitHub!
Here is the repo address: https://github.com/Leeway213/BSP-aw1689
And also some driver source code here with A64 datasheet in readme: https://github.com/Leeway213/driver-samples
Welcome makers developers and anyone-elsers to post your feedback.
  • BPI-M64 Android 6.0.1 source code
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjdTRVRVFaSHd2cnc
  • BPI-M64 Linux kernel 3.4 BSP code:
github link : https://github.com/BPI-SINOVOIP/BPI-M64-bsp
  • BPI-M64 Win10 IoT source code
https://bananapi.gitbooks.io/bpi-m64/content/en/sourcecodeongithub.html
documents
  • schematic diagram:
google driver : https://drive.google.com/file/d/0B4PAo2nW2KfnUE5tMGItNkZjMzg/view?usp=sharing
baidu cloud : http://pan.baidu.com/s/1kVRpcYb
BPI-M64 BT Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64bt40labtest.html
BPI-M64 WIFI Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m264wifilabtest.html
BPI-M64 Validation test : https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64validationtestreport.html
CE FCC RoHS : http://forum.banana-pi.org/t/bpi-m64-ce-fcc-rohs-certification/2747
  • 2018-05-20 update ,android 7.0
hdmi-Version and Lcd 5.0 version
baidu cloud : https://pan.baidu.com/s/1O3PsI73WmFFvhxMmzEscIQ
  • 2017-05-11 update ,android 6.0
HDMI-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjcF9USm1MWWtxSXc
Baidu Cloud:https://pan.baidu.com/s/1bHWhlW
MD5: f85281213b9c5b88008a487dd1b6963c
LCD-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjdHpFbHJMQWtsbFk
Baidu Cloud:https://pan.baidu.com/s/1kVJVPGV
MD5:be27e4eced96d3de81d46e512fd978eb
forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-android-6-0-version-v3/3240/4
Win 10 IoT
  • 2017-1-13 updae Win10 IoT Core beta0.2
baidu cloud :http://pan.baidu.com/s/1c2ce100
  • Win10 IoT Core 10586 beta0.1
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjODJOSS1TdkRvcEk
baidu link : http://pan.baidu.com/s/1dEQyGgD
MD5: 1c09118cd45bf0c3b61d1846710a3649
kernel 4.4
  • 2018-4-17 update Ubuntu 16.04.4 with linux kernel 4.4.89
image name:2018-04-17-ubuntu-16.04-mate-desktop-demo3-k4.4.89-vdpau-3-mic-docker-bpi-r18-avs-aarch64-sd-emmc.img.zip
Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
MD5: 4b7e163d260e58a39ba8905e7ed39943
Forum pthread:http://forum.banana-pi.org/t/bpi-r18-avs-new-image-ubuntu-16-04-4-with-linux-kernel-4-4-89-2018-4-17/5435
Kernel 3.10.105
  • 2017-08-14 update based on ubuntu 16.04.3 LTS Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjN1h1U0xDYUxET00/view?usp=sharing
baidu cloud: http://pan.baidu.com/s/1pLkbdTT
MD5: ae34baa840874276858d936a7ca85c4f
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-14-ubuntu-16-04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc/3695
  • 2017-08-13 debian 8.9 jessie Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjazlNRTRHei1NbmM/view?usp=sharing
baidu cloud:http://pan.baidu.com/s/1eSeTQeA
MD5: 9ddf067457ebaf193de63c5c7141446a
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-13-debian-8-jessie-mate-desktop-preview-aarch64-bpi-m64-sd-emmc/3694
Image lownload link :https://www.armbian.com/bananapi-m64/
  • Armbian OS aarch64
download link:http://geektillithertz.com/wordpress/index.php/2017/01/04/armbian-os-banana-pi-m64/
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-armbian-os-aarch64-for-bpi-m64-download/2724
FreeBSD
Others
