Getting Started with R2
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface
  • SATA interface
 1.Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
 2.Using your USB-Serial Connect debug console on R2
Load your first image on R2
 * apt-get install pv
Build your own image on R2
OpenWrt
 2. You need to have installed gcc, binutils, bzip2, flex, python, perl, make, find, grep, diff, unzip, gawk, getopt, subversion,
 libz-dev and libc headers.
 3. Run "./scripts/feeds update -a" to get all the latest package definitions defined in feeds.conf / feeds.conf.default respectively
 and "./scripts/feeds install -a" to install symlinks of all of them into package/feeds/.
     you will find two images:
     * mtk-bpi-r2-EMMC.img
     * mtk-bpi-r2-SD.img
 (2) Write image to TF card, execute "bpi-copy if=mtk-bpi-r2-SD.img of=/dev/sdX"
 (3) If you want to install image to EMMC, We need another system which is running on SD card to program EMMC image to EMMC,
     please follow below steps to do:
     * Change the Partition configurion of EMMC is 48h: reboot the system which is running SD, and enter the U-boot command line,
       run command emmc pconf 48 (for this steps, we can change partition configuration in userspace by using mmc-utils,
       see more information in BPI-R2 OpenWrt(LEDE) Souce code : 2018-04-11)
 * Copy "bin/targets/mediatek/32/lede-mediatek-32-bananapi,bpi-r2-sysupgrade.tar" to R2 board which is running OpenWrt
   system(no matter where(SD or EMMC) it boots from), and then run command “sysupgrade lede-mediatek-32-bananapi,bpi-r2-sysupgrade.tar”
   to update both kernel and rootfs.
Develop 4G module with R2
Wifi and Ap mode on R2
Make your own image
Reference Link
