Getting Started with R2
Revision as of 20:06, 6 May 2018 by JackZengWiki (talk | contribs) (OpenWrt)
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface
  • SATA interface
 1.Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
 2.Using your USB-Serial Connect debug console on R2
Load your first image on R2
 * apt-get install pv
Build your own image on R2
 Execute "git clone [email protected]:BPI-SINOVOIP/BPI-R2-bsp.git"
OpenWrt
 Execute "git clone https://github.com/garywangcn/bpi-r2_lede.git"
 2. You need to have installed gcc, binutils, bzip2, flex, python, perl, make, find, grep, diff, unzip, gawk, getopt, subversion, libz-dev and libc
 headers.
 3. Run "./scripts/feeds update -a" to get all the latest package definitions defined in feeds.conf / feeds.conf.default respectively
 and "./scripts/feeds install -a" to install symlinks of all of them into package/feeds/.
 Choose "Target System" to config as "MediaTek Ralink ARM"
 Choose "Boot Loaders" to config as "u-boot-bpi_r2"
 6. After built, enter to "build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_32/", you will find two images
 mtk-bpi-r2-EMMC.img
 mtk-bpi-r2-SD.img
Develop 4G module with R2
Wifi and Ap mode on R2
Make your own image
Reference Link
