BPI-PC101 gesture recognition module
Revision as of 02:03, 5 June 2018 by Sinovoip (talk | contribs) (Created page with " = Introduction= thumb|Overview: BPI:bit thumb|Overview: BPI:bit File:BPi_bit_webduino_3.jpg|thumb|Overview: BPI:bit f...")
Overview: BPI:bit
Overview: BPI:bit
  • Button switch : GPIO35 (A), GPIO27 (B)
  • Buzzer: GPIO25
  • MPU-9250 9-axis sensor: GPIO0, GPIO21, GPIO22, GPIO33
Description
Interface
Edge interface
PIN definitions
