Getting Started with M3
Revision as of 00:38, 1 June 2018 by JackZengWiki (talk | contribs) (Load your first image on M3)
BPI-M3
Overview: BPI-M3 respbian linux
  • Octa-core 1.8GHz Powerful CPU
  • 2 GB LPDDR3 memory
  • 8 GB eMMC storage
  • WiFi & Bluetooth onboard
Development For Android
 * Prepare 8G/above TF card, USB-Serial interface, PC with Windows System
 * Using your USB-Serial Connect debug console on M3
Development For Linux
 * Here is the example link: http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-release-raspbian-jessie-8-0-2018-5-28-v1-1/5847
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M3, and press power button setup M3
 File:M3 Android.png
 * Run your M3 with TF card
 * Plug your USB disk in M3
 * After M3 recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M3, take TF card out, power on M3
How to buld M3 Bsp code
 * Prepare a PC which runs ubuntu
 * Install Docker-ce on your PC,https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-ce
 * After install Docker, execute "docker pull sinovoip/bpi-build:ubuntu12.04", to pull image
 * Then you pulled image, execute "docker run --privileged -d -p 2222:22 -v /media:/media sinovoip/bpi-build:ubuntu12.04"
 * "ssh -p 2222 [email protected] #default passwd is root"
 * Execute "git clone https://github.com/BPI-SINOVOIP/BPI-M3-bsp.git" on your ubuntu terminal
 * Execute "./build.sh" to build M3 bsp code
 * After built, open a new terminal, execute "docker cp xxxxx(your container id):xxxxx(your project path) xxxxx(your pc path)"
Make your own image
Make one raspbian image
  • Prepare a SD card which have installed Raspbian system
  • Boot your SD card with M3, after M3 finish starting, copy your files and config your Raspbian, then poweroff M3
  • Execute "bpi-migrate -c bpi-m3.conf -c raspbian-jessie-from-sd.conf -d /dev/sdx"
SATA
1. Mount SATA on M3
  • "mount /dev/sdx /mnt/xxx"
OTG
1. On M3 console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M3 and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M3 OTG
  • If yes, we could execute "adb shell" to connect M3 by adb now
LCD 5" & LCD 7"
  • Find "BPI_M3_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-M3/BPI_M3_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M3 console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M3
  • ip link set wlan0 up
  • dhclient wlan0
Ov5640
Ov8865
  • "/test_ov8865.sh"
IR function
  • Execute "getevent"
  • Use your IR device to send information to M3
WringPi
File System
