BPI BerryClip Module
Revision as of 02:45, 31 May 2018 by Sinovoip (talk | contribs) (How to use)
Product Overview
The module is designed specifically for learning control the GPIO of Banana Pi. There are 6 LED, 1 button and 1 Beep on the module; All of them can use the GPIO of Banana Pi to control. The beginner can learn the INPUT mode of GPIO through the key and learn the OUTPUT mode through the LED or Beep
Product Feature
  • 1. 6 multicolor LED
  • 2. 1 single button on board
  • 3. 1 Beep on board
Product specification
Port
BananaPi 2X13 port,also can use on raspberry pi.
Product Parameters
  • 1. Working voltage: 3.3V
  • 2. LED max current allow 8mA
  • 3. Beep max current allow 12mA
Typical Application
  • 1. Hardware beginner learning
  • 2. Education
Insert the BerryClip in the Banana Pi, Pay attention don’t make the direction reversed! The correct direction of insert module is above the Banana Pi’s PCB.
Testbench
  • 1. Setup the GPIO OUTPUT, Output LED High level, the LED will be lighten;
  • 2. Setup the GPIO INPUT, press the button;
  • 3. Test finish
Example and Test Code
#include <wiringPi.h>
int LED1[]={7,0,3,12,13,14};
int i;
int initIO()
pinMode(7,OUTPUT);
pinMode(0,OUTPUT);
pinMode(3,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
pinMode(14,OUTPUT);
int LED()
for(i=0;i<=6;i++)
digitalWrite(LED1[i],1);
delay(500);
digitalWrite(LED1[i],0);
delay(500);
int main()
int val;
wiringPiSetup();
 initIO();
pinMode(10,INPUT);
digitalWrite(11,1);
while(1)
val=digitalRead(10);
if(val==0)
LED();
digitalWrite(11,1);
i=0;
How to use
BPI BerryClip 6 LED Module and how to use on BPI-M3
OS: BPI-M3 Ubuntu15.10 (Kernel3.4)
Version: 1.0 HDMI
Step 1: Download WiringPI
$ git clone https://github.com/BPI-SINOVOIP/BPI-WiringPi.git -b BPI_M3
$ cd BPI-WiringPi
$ chmod +x ./build
$ sudo ./build
Step 2 : Copy smaple code to BerryClip.c file
$ sudo vi BerryClip.c
Step 3 : Compile BerryClip.c
$ gcc -o BerryClip BerryClip.c -l wiringPi
Step 4 : Run BerryClip
$ sudo ./BerryClip
Step 5: Press the button to see if it works
Video demo on youtube:
https://www.youtube.com/watch?v=kIPbm86sqnw
Forum pthread
http://forum.banana-pi.org/t/bpi-m3-bpi-berryclip-6-led-module-and-how-to-use/1077
others
1:58 Raspberry Pi - Quake 3 demo Liz Upton 1.5M views
8:27 Problem with the Patriots still being hailed as the team to beat? | UNDISPUTED 5/30/2018 First Take Recommended for you New
6:58 Is Jeff Van Gundy right that any game the Cavs win in the Finals.. | FIRST THINGS FIRST 5/30/2018 First Take Recommended for you New
7:43 Buying that Nick Foles had no say in potential trade offer? | UNDISPUTED 5/30/2018 First Take Recommended for you New
7:47 Do Cavs have any shot against Warriors? | THE HERD 5/29/2018 First Take Recommended for you New
3:04 Starting to believe the Lakers will give Gelo a chance? | UNDISPUTED 5/30/2018 First Take Recommended for you New
37:30 Communication between Arduino, RaspberryPi and Server madhu venkatesh 52K views
13:45 Michael Jordan last 3 minutes in his FINAL BULLS GAME vs Jazz (1998) pennyccw Recommended for you
2:42 Skip and Shannon’s reaction to the Lakers working out LiAngelo Ball | NBA | UNDISPUTED Skip and Shannon: UNDISPUTED Recommended for you New
10:15 Antoine Walker-Kevin Durant on criticism he can't carry team like.. | FIRST THINGS FIRST 5/30/2018 First Take Recommended for you New
Raspberry Pi Home Assistant Setup misperry 27K views
Jabra PRO900Series Loja Mundi 3 views
Node Red MQTT on the Raspberry Pi Richard Wenner 163K views
Raspberry Pi Custom Web Control misperry 99K views
SuperHouseTV #17: Home automation control with Sonoff, Arduino, OpenHAB, and MQTT SuperHouseTV 247K views
Banana Pi BerryClip 6LED use on BPI-M2 demo : https://www.youtube.com/watch?v=E_LQXyNECNQ
