BPI-Bit
- Button switch : GPIO35 (A), GPIO27 (B)
- Buzzer: GPIO25
- MPU-9250 9-axis sensor: GPIO0, GPIO21, GPIO22, GPIO33
Description
Interface
Edge interface
PIN definition
| P8 | GPIO16 | ||||
| P9 | GPIO17 | ||||
| P13 | GPIO18 | SPI_SS | |||
| 3V3 | POWER:3V3 | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
5*5 LED list
| 20 | 15 | 10 | 5 | 0 |
| 21 | 16 | 11 | 6 | 1 |
| 22 | 17 | 12 | 7 | 2 |
| 23 | 18 | 13 | 8 | 3 |
| 24 | 19 | 14 | 9 | 4 |
MPU9250 9-axis sensor
The 9-axis is the combination of 3 separate triple axis sensors. For more detailed information of this chip, click here[1] to view the datasheet.
bpi:bit VS micro:bit
| CPU | Dual-core 32bit Xtensa LX6, up to 240MHz | 32bit ARM Cortex M0, up to 16MHz | |||||
| RAM | 520KB | 16KB | |||||
| ROM | 448KB | Unkown | |||||
| Flash | 4MB | 256KB | |||||
BPI-bit software
BPI:bit for webduino
About webduino
Webduino working principle:
- 1 use WebComponents integration Breakout.
- 2 use WebSocket(Firmata) to interacting with the server.
- 3 Server use TCP/IP(Firmata) to control webduino terminal.
| Webduino project VS Arduino and micro:bit project | |||
| item compared | Webduino | Arduino | Micro:bit |
| development language | HTML/JavaScript | C/C++ | Python/JavaScript |
| development environment | WEB browser | Arduino IDE | JavaScript Blocks |
| Simulator | Webduino Simulator | Third-party support | Microsoft MakeCode |
| graphical programming | Wbduino blockly | Third-party Scratch | Blockly |
| Cloud Server | webduino cloud | N/A | N/A |
| attended mode | WiFi | USB | USB |
| Update the program | web online update | USB burn | USB disk |
- Quick start Webduino Blockly and simulator
Note: BPI:bit have burn webduino Firmware defaults. Only when you clear the factory Settings and use arduino open source, will you need to burn webduinofirmware again.
Burning method:
Select ESP32 DownloadTool:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | SPI SPEED | 40MHz | |
| 2 | SPI MODE | DIO | |
| 3 | FLASH SIZE | 32Mbit | |
| 4 | COM | COMx(Fill in the port number assigned by the computer) | |
| 5 | BAUD | 1152000 | |
During the burning process:
Finished:
Burn time is about 20s
BPI: bit Online tutorials
BPI:bit for arduino
Arduino IDE
microPyhton
Scratch
- BPI:bit for webduino source code on github: https://github.com/webduinoio
- BPI:bit for arduino Source code on Github: https://github.com/yelvlab/BPI-BIT
documents
- BPI:bit dxf file : http://forum.banana-pi.org/uploads/default/original/2X/0/0b86ccaeb565cdeef093164fd1ff837727ca2887.rar
- Taiwan server : http://webuino.io
- Overworld server: http://webduino.io
- china mainland : http://www.webduino.com.cn
- Easy to buy BPI:bit sample form aliexpress
- Facebook group
