BPI Zigbee BT5.0 IoT module
Revision as of 02:56, 24 May 2018 by Sinovoip (talk | contribs) (Module Specifications)
Overview:BPI Zigbee BT 5.0 IoT module
Overview:BPI Zigbee BT 5.0 IoT module front
Overview:BPI Zigbee BT 5.0 IoT module back
BPI Zigbee BT5.0 IoT module use Silicom Silicon Labs’Mighty Gecko MGM12P module onboard design.
Silicon Labs’ Mighty Gecko MGM12P module integrates our EFR32MG12 Mighty Gecko SoC into a small form factor module for zigbee, Thread and Bluetooth low energy (LE) networks. With 1024 kB of Flash and 256 kB of RAM, this module is ideal for applications that require multiple protocols. Modules enable the fastest time to market and are ideal for lower volume (< 100K) applications. The fully certified modules integrate all components (Crystals, RF passives and Antenna) required for a system-level implementation of zigbee, Thread and BLE networks. With +10 dBm and +17 dBm versions, the modules can meet the WW regulatory requirements for IEEE 802.15.4 2.4 GHz used in both zigbee and Thread networks as well 2GFSK used in BLE networks.
Module Benefits
  • Built on Silicon Labs Mighty Gecko SoC family
  • Up to 122 dBm link budget
  • Internal chip antenna and external antenna (U.FL) variants
  • Provides rapid time-to-market with onboard stack, antenna and regulatory certifications
  • Supported by Silicon Labs reliable, secure and flexible mesh protocol stacks
  • Supports multi-protocol with BLE and zigbee
  • Uses same development tools as the Mighty Gecko ICs; Simplicity Studio, Energy Monitor, Packet Trace
  • Can support SoC or network co-processor architectures
  • Provides customers with an easy upgrade path to a discrete SoC design
  • Footprint compatible with MGM111 modules
  • zigbee and Thread Radio:
2.4 GHz IEEE 802.15.4
250 kbps O-QPSK DSSS
Down to -105 dBm Receive Sensitivity
Up to +17 dBm Programmable Output Power
10.8 mA RX current
10.0 mA Active-mode TX at 0 dBm
  • Bluetooth:
Compatible with Bluetooth 5 Specification
1 Mbps GFSK
Down to -101.6 dBm receive Sensitivity
Up to +18 dBm Programmable Output Power
10.3 mA RX Current
9.5 mA TX at 0 dBm
  • Rich Analog and Digital Peripherals:
AES256/128 Hardware Crypto Accelerator with ECC, SHA-1, SHA-2
ADC (12-bit, 1 Msps)
Current DAC (4-bit, Current Source or Sink)
VDAC and IDAC
3 X Operational Amplifier
Low-Energy Sensor Interface
Multi-channel Capacitive Sense interface
2 X Analog Comparator
Low Energy UART
4 X USART (UART, SPI, IrDA, I2S)
1²C (Address recognition down to EM3)
Timers: RTCC, LE Timer & Pulse Counter
12-channel Peripheral Reflex System
25 GPIO
  • Microcontroller:
ARM Cortex®-M4
Up to 40 MHz Clock Speed
Low Active Mode Current: 70 µA/MHz
1024 kB of Programmable Flash
256 kB RAM SRAM
  • Energy Efficient Low Power Modes:
Energy Mode 2 (Deep Sleep) Current: 2.0 µA
Ultra-fast wake up: 3 µS from EM3
Wide Supply Voltage range of 1.8 to 3.8 V
  • Dimensions:
12.9 mm x 17.8 mm x 2.1 mm
