Getting Started with M2P
BPI-M2+ H3
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
1.You could download latest image from our forum * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
How to build kernel
=How to build uboot
=How to create a image
- Use iperf3 to test gmac
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2P
drive coce:
We use HDF5640 camara.
- test_ov5640_image_mode.sh
- cameratest.sh
IR function
- Execute getevent
WringPi
- Execute bpi_test_lcd1602
- Execute bpi_test_52pi
- Execute bpi_test_gpio40
