Getting Start with M2U
File:M2p respbian.jpg
Overview: BPI-M2U respbian linux
BPI-M2U
  • Quad Core ARM Cortex A7 CPU R40
  • 2GB DDR3 SDRAM
  • 8 GB eMMC storage
  • SATA Interface
Load your first image on M2U
 * Here is the example forum thread link:
 * apt-get install pv
SATA
If you meet some errors when you mount SATA, try these following commands:
  • "fdisk /dev/sdx" to create new partition , after created input "wq" to save and quit.
  • "mount /dev/sdx /mnt/xxx"
After you success to insert SATA, we could input following commands to test SATA interface:
OTG
LCD 5"
LCD 7"
  • Find "BPI_M2U_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m2u/BPI_M2U_LCD7.img.gz"
Touch screen
  • Use iperf3 to test gmac
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2U
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
  • test_ov5640_image_mode.sh
  • cameratest.sh
IR function
  • Execute getevent
  • Use your IR device to send information to M2U
WringPi
  • Execute bpi_test_lcd1602
  • Execute bpi_test_52pi
  • Execute bpi_test_gpio40
Reference Link
http://forum.banana-pi.org/
