Banana Pi BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
- Allwinner R40/V40 Quad Core ARM Cortex A7 CPU
- 1GB DDR3 SDRAM.
- SATA Interface.
- 4*USB 2.0
| HardWare Specification of Banana pi BPI-M2 Berry | |||
| Soc | Allwinner R40/V40 | ||
| SDRAM | 1GB DDR3 with 733MHz\(shared with GPU\) | ||
| Bluetooth | BT4.0 | ||
| On board Storage | MicroSD \(TF\) card,No eMMC onboard | ||
| Audio outputs | HDMI, analog audio \(via 3.5 mm TRRS jack\), I2S audio \(also potentially for audio input\) | ||
| USB | 4 USB 2.0 host, 1 USB 2.0 OTG | ||
| IR | No onboard IR receiver | ||
| DC Power | 5V/2A with micro USB port | ||
| battery | No 3.7V lithium battery power support | ||
| Weight | 40g | ||
| CON1-P01 | VCC-3V3 | ||
| CON1-P02 | DCIN | ||
| CON1-P04 | DCIN | ||
| CON1-P06 | GND | ||
| CON1-P09 | GND | ||
| CON1-P11 | UART7-TX | PI20 | PWM2 |
| CON1-P14 | GND | ||
| CON1-P17 | VCC-3V3 | ||
| CON1-P20 | GND | ||
| CON1-P21 | PC1 | ||
| CON1-P22 | PH27 | CSI1-VSYNC | | ||
| CON1-P25 | GND | ||
| CON1-P30 | GND | ||
| CON1-P34 | GND | ||
| CON1-P39 | GND | ||
