Banana Pi BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
  • 1GB DDR3 SDRAM.
  • SATA Interface.
  • 4*USB 2.0
HardWare Specification of Banana pi BPI-M2 Berry
Soc Allwinner R40/V40
SDRAM 1GB DDR3 with 733MHz\(shared with GPU\)
SATA suppoort SATA interface
Bluetooth BT4.0
On board Storage MicroSD \(TF\) card,No eMMC onboard
USB 4 USB 2.0 host, 1 USB 2.0 OTG
IR No onboard IR receiver
battery No 3.7V lithium battery power support
Weight 40g
Default Function | Function2:GPIO | Function3 | VCC-3V3 | | DCIN | | TWI2-SDA | PB21 | PWM5 | DCIN | | TWI2-SCK | PB20 | PWM4 | GND | | PB3 | PB3 | PWM1 | UART2-TX | PI18 | SPI1\_MOSI | GND | | UART2-RX | PI19 | SPI1\_MISO | UART7-TX | PI20 | PWM2 | UART2-CTS | PI17 | SPI1\_CLK | UART7-RX | PI21 | PWM3 | GND | | PH25 | PH25 | CSI1-FIELD | UART2-RTS | PI16 | SPI1\_CS0 | VCC-3V3 | | PH26 | PH26 | CSI1-HSYNC | SPI0\_MOSI | PC0 | | GND | | SPI0\_MISO | PC1 | | PH27 | PH27 | CSI1-VSYNC | SPI0\_CLK | PC2 | | SPI0\_CS | PC23 | | GND | | PH24 | PH24 | CSI1-PCLK | TWI3-SDA | PI1 | | TWI3-SCK | PI0 | | PH0 | PH0 | CSI1-D0 | GND | | PH1 | PH1 | CSI1-D1 | PD20 | PD20 | CSI1-MCLK | PH2 | PH2 | CSI1-D2 | GND | | PH3 | PH3 | CSI1-D3 | UART5-RX | PH7 | CSI1-D7 | UART4-TX | PH4 | CSI1-D4 | UART5-TX | PH6 | CSI1-D6 | GND | | UART4-RX | PH5 | CSI1-D5 | |
Opnewrt
Release
