Banana Pi BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
- Allwinner R40/V40 Quad Core ARM Cortex A7 CPU
- 1GB DDR3 SDRAM.
- SATA Interface.
- 4*USB 2.0
| HardWare Specification of Banana pi BPI-M2 Berry | |||
| Soc | |||
| CPU | |||
| GPU | |||
| SDRAM | |||
| SATA | |||
| GPIO | |||
| On board Network | |||
| Wifi Module | |||
| Bluetooth | |||
| MicroSD \(TF\) card,** **_**No eMMC onboard**_ | | |||
| 4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4 | | |||
| Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,support video encodeing:High-deinition\(HD\)H.264 video encoder is up to 1080P@45fps | | |||
| HDMI, analog audio \(via 3.5 mm TRRS jack\), I2S audio \(also potentially for audio input\) | | |||
| A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps | | |||
| Audio input | |||
| USB | |||
| Buttons | |||
| Leds | |||
| IR | |||
| DC Power | |||
| battery | |||
| Sizes | |||
| Weight | |||
