Getting Started with BPI-W2
Read more: Banana Pi BPI-W2
Load your first image on W2
Build your own image on W2
How to make and run the 64-bit ubuntu 16.04 on SD card 2018-4-28
1.Requirement:
- 2.A banana Pi W2 board;
- 3.A SD card;
- ouImage – kernel image
Requirement:
A windows PC runs serial terminal tool like hypertrm. (I recommend using “hypertrm”, because other tools sometimes fail to transmit data); Latest version u-boot binary file from Banana Pi website (dvrboot.exe.bin); A hardware configuration binary file for W2 (RTD1296_hwsetting_BOOT_4DDR4_4Gb_s1866_padding.bin); Steps:
Connect the serial port between the host and the board correctly, run the terminal software and set up the relevant parameters (115200, 8N1, none);
press “ctrl+q” then to power on the board, and when the screen appears’ d/g/r ', it can be released;
Input “h” and send hardware configuration binary files (RTD1296_hwsetting_BOOT_4DDR4_4Gb_s1866_padding.bin) in Y-modem mode on the terminal side.
Wait for the transfer to complete, then input below in console:
s98007058
01500000
Input “d” and send u-boot binary files (dvrboot.exe.bin) in Y-modem mode on the terminal side.
Wait for the transmission to complete. Enter “g” then the u-boot will be programed to the EMMC automatically.
Requirement:
A PC runs linux (recommend ubuntu) The latest version of ubuntu tar file for arm64 (ubuntu-base-16.04.4-base-arm64.tar.gz) is downloaded from ubuntu website: http://cdimage.ubuntu.com/ubuntu-base/releases/16.04/release/ 17 Steps: (on the host):
mkdir rootfs
su root
tar zxvf ubuntu-base-16.04.4-base-arm64.tar.gz -C rootfs
write a shell script file, please copy below contents to the file ch-mount.sh (vi ch-mount.sh and copy):
!/bin/bash
function mnt() {
echo "MOUNTING"
sudo mount -t proc /proc ${2}proc
sudo mount -t sysfs /sys ${2}sys
sudo mount -o bind /dev ${2}dev
sudo mount -o bind /dev/pts ${2}dev/pts
sudo chroot ${2}
function umnt() {
echo "UNMOUNTING"
sudo umount ${2}proc
sudo umount ${2}sys
sudo umount ${2}dev/pts
sudo umount ${2}dev
if [ "$1" == "-m" ] && [ -n "$2" ] ;
then
mnt $1 $2
elif [ "$1" == "-u" ] && [ -n "$2" ];
then
umnt $1 $2
else
echo ""
echo "Either 1'st, 2'nd or both parameters were missing"
echo ""
echo "1'st parameter can be one of these: -m(mount) OR -u(umount)"
echo "2'nd parameter is the full path of rootfs directory(with trailing '/')"
echo ""
echo "For example: ch-mount -m /media/sdcard/"
echo ""
echo 1st parameter : ${1}
echo 2nd parameter : ${2}
fi
apt-get install qemu-user-static
cp /usr/bin/qemu-aarch64-static rootfs/usr/bin
cp -b /etc/resolv.conf rootfs/etc/
./ch-mount.sh -m rootfs/
apt-get install iputils-ping
apt-get install udev
apt-get install net-tools
Modify the root password by running: “passwd root”
exit
./ch-mount.sh -u rootfs/
Until now, the ubuntu file system have been built successfully on the host, next we will write it to the SD card.
Requirement:
A SD card; Device tree binary file downloaded from Banana Pi website: bpi-w2.dtb; Kernel image file downloaded from Banana Pi website: uImage; Video and Audio firmware file downloaded from Banana Pi website: bluecore.audio; Steps:
Using fdisk tool to create two partitions in SD card: format the first partition as FAT32, and the second partition as ext4; It’s recommended that the first partition size should not be less than 100M;
Copy the three files: bpi-w2.dtb, uImage, bluecore.audio to the first partition;
Copy the all files in root filesystem which just built by us to the second partition using root privilege:
Eject the SD card and insert it to the W2 board, after power on the board, you can see the ubuntu is running now.
Set up network and get packages by using apt-get from ubuntu repository
Steps:
Log in with root and the password was set by yourself; Ifconfig eth0 or eth1: ifconfig eth1 192.168.2.231 Add default gateway to let the board can reach internet: route add default gw 192.168.2.1 Add a DNS: echo ‘nameserver 8.8.8.8’ >> /etc/resolv.conf apt-get update then you can fetch and install any packages from ubuntu by using apt-get. 6.Furthermore:
PDF format file download
Ubuntu 16.04 Install and run Node.js and http-server
- insltall Node.js
OpenWrt
Burn OpenWRT with Linux kernel 4.4
1.About this release
2.Burn OpenWRT on W2 steps:
- MP_Tool
- Set your console parameters
- Choose "LK option"
- hypertrm
::s98007058 ::01500000
- U disk
- install.img
2)Burn OpenWRT on W2 steps:
emmc.uImage
bluecore.audio
rescue.emmc.dtb
save
go ru
3.Image & Tools link:
Baidu Drive: https://pan.baidu.com/s/1Rs9F46wNJibORaeCfVh4wg PinCode:1w4w
4.BPI-W2 run OpenWRT video:
