Banana Pi BPI-M6 with Synaptics VS680
Banana Pi BPI-M5 Amlogic S905X3 Processor
Banana Pi BPI-M4 Realtek RTD1395
Banana Pi BPI-M64 Allwinner A64
Banana Pi BPI-M2+ Allwinner H3/H5/H2+]3
About VideoSmart VS680
Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
NPU for AI up to 6 .75Tops
4GB LPDDR4
16GB eMMC flash
M.2 Key E(PCIe + MIPI CSI)
4 USB 3.0
1 GbE ethernet
1 HDMIin and 1 HDMIout
HardWare Specification of Banana pi BPI-M6
CPU
GPU
NPU for AI
Up to 6 .75Tops
Memory
4 GB LPDDR4
Storage
MicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB
Network
10/100/1000 Mbit/s Ethernet ,Optional WiFi USB dongle
Video
1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port
Audio Output(s)
1 x HDMI digital output
Display
MIPI DSI interface
M.2 interface
USB ports
USB 3.0 PORT (x4)
GPIO
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM
Switches
SPI boot and U-boot
LED
Power Status and Activity status
Power Source
5 volt @3A TYPE C
Size & Weight
92x60mm, 48g
OS
Android and Linux
BPI-M6 40PIN Header(CON3)
BPI-M6-CON3
PIN
PIN
BPI-M6-CON3
PWR_3V3_CTL
PWR_5V
GPIO46/TW0_SDA
3
4
PWR_5V
GPIO47/TW0_SCL
5
6
GND
GPIO53/PWM1
7
8
SM_GPIO15/UART2_TXD
GND
9
10
SM_GPIO14/UART2_RXD
GPIO36/PWM3
11
12
GPIO20/I2S1_BCLK
GPIO37/PWM2
13
14
GND
EXPANDER_TW3_GPIO1_4
15
16
EXPANDER_TW3_GPIO1_0
PWR_3V3_CTL
17
18
EXPANDER_TW3_GPIO1_1
SM_GPIO13/SPI2_SDO/URT2_RTS/SM_STRAP1
19
20
GND
SM_GPIO12/SPI2_SDI/URT2_CTS
21
22
GPIO4/SPDIF
SM_GPIO11/SPI2_SCK
23
24
SM_GPIO17/SPI2_SS0/SM_STRAP2
GND
25
26
SM_GPIO16/SPI2_SS1/SM_STRAP3
GPIO15/I2S1_DO3
27
28
GPIO16/I2S1_DO2
EXPANDER_TW3_GPIO1_7
29
30
GND
EXPANDER_TW3_GPIO1_6
31
32
EXPANDER_TW3_GPIO1_3
EXPANDER_TW3_GPIO1_5
33
34
GND
GPIO21/I2S1_LRCK
35
36
EXPANDER_TW3_GPIO1_2
GPIO18/I2S1_MCLK
37
38
GPIO17/I2S1_DO1
GND
39
40
GPIO19/I2S1_DO0
M.2 E-KEY(CN10)
BPI-M6 M.2 E-KEY(CN10)
PIN
PIN
GND
VCC-NGFF
NGFF_KEYE_DP
3
4
VCC-NGFF
NGFF_KEYE_DM
5
6
WiFi-LED
GND
7
8
SM_GPIO10/TW3_SDA
MIPI_CSI0_RD0p
9
10
SM_GPIO9/TW3_SCL
MIPI_CSI0_RD0n
11
12
NI
MIPI_CSI0_RD1p
13
14
BT-LED
MIPI_CSI0_RD1n
5
16
BT-LED
MIPI_CSI0_RD2p
17
18
GND
MIPI_CSI0_RD2n
19
20
SM_GPIO6/UART_WAKE#Puboot
MIPI_CSI0_RD3p
21
22
GPIO43/UART3_RXD
MIPI_CSI0_RD3n
23
24
NOTCH
NOTCH
25
26
NOTCH
NOTCH
27
28
NOTCH
NOTCH
29
30
NOTCH
NOTCH
31
32
GPIO42/UART3_TXD
GND
33
34
GPIO41/UART3_CTSn
PCIe_TX0p
35
36
GPIO40/UART3_RTSn
PCIe_TX0n
37
38
NI
GND
39
40
MIPI_CSI0_RCKp
PCIe_RX0p
41
42
MIPI_CSI0_RCKn
PCIe_RX0n
43
44
NI
GND
45
46
NI
PCIe_CLKp
47
48
NI
PCIe_CLKn
49
50
CLK32_OUT
GND
51
52
PCIE_PERSTn
PCIE_CLKREQ
53
54
GPIO10/DISABLE_BT
PCIE_PEWAKE
55
56
GPIO09/DISABLE_WiFi
GND
57
58
GPIO46/TW0_SDA(VDDIO_1.8V)
PCIe_TX1p
59
60
GPIO47/TW0_SCL(VDDIO_1.8V)
PCIe_TX1n
61
62
NI
GND
63
64
MIPI_CSI1_RD0p
PCIe_RX1p
65
66
MIPI_CSI1_RD0n
PCIe_RX1n
67
68
MIPI_CSI1_RD1p
GND
69
70
MIPI_CSI1_RD1n
MIPI_CSI1_RCKp
71
72
VCC-NGFF
MIPI_CSI1_RCKn
73
74
VCC-NGFF
GND
75
MIPI DSI(CN12)
BPI-M6 MIPI DSI(CN12)
CN12-P1
MIPI_DSI_TX1_D0n
CN12-P2
MIPI_DSI_TX1_D0p
CN12-P3
MIPI_DSI_TX1_D1n
CN12-P4
MIPI_DSI_TX1_D1p
CN12-P5
MIPI_DSI_TX1_CLKn
CN12-P6
MIPI_DSI_TX1_CLKp
CN12-P7
MIPI_DSI_TX1_D2n
CN12-P8
MIPI_DSI_TX1_D2p
CN12-P9
MIPI_DSI_TX1_D3n
CN12-P10
MIPI_DSI_TX1_D3p
CN12-P11
GND
CN12-P12
LCD_ADC
CN12-P13
GPIO2/LCD1_PWR_EN(VDDIO_1.8V)
CN12-P14
GPIO3/LCD1_RST(VDDIO_1.8V)
CN12-P15
GPIO39/LCD1_BL_PWM(VDDIO_1.8V)
CN12-P16
GND
CN12-P17
GPIO0/TP_INT(VDDIO_1.8V)
CN12-P18
GPIO1/TP_RST(VDDIO_1.8V)
CN12-P19
CN12-P20
CN12-P21
GND
CN12-P22
GND
CN12-P23
PWR_5V
CN12-P24
PWR_5V
Debug UART(CON2)
BPI-M6 Debug UART(CON2)
CON2-P1
GND
CON2-P2
UART0-RX
CON2-P3
UART0-TX
Source code on github
Armbian Source code:
Linux Source code:
BPI-M6 VS680 SOC System Tool Manual V1.3.2.1
Baidu Cloud: https://pan.baidu.com/s/1tX7UVSJQOcNhMlazQRQkpw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1gQalGLqNN24TeTBmJGzS0e3HeXxRD1fP/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/18VTAdGtQFb2nu1bku8mHBw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1z-o5dZWcYrmTqNH3Wz9ttWUzptveCS6s/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1Ngc11CcnufAdDcdwMd2mmQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1HJmpC5L3YqrJt4IsN0SMD5HoowqfGCyU/view?usp=sharing
2023-08-30 release aosp_dolphin_tablet-syna-image-lpddr4x
Baidu Cloud: https://pan.baidu.com/s/1unEibD-NI8-Ti5le2E6d7g?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/file/d/1egPBOusdlNGJDdp5muAjiv2MvMya0F-H/view?usp=sharing
2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bookworm_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/1NqAxVm4XXUh95T8a7MI6lg?pwd=8888 (pincode:8888)
Google drive:
2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bullseye_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/1nxF_DtdgjL5Qey9_FA3KlA?pwd=8888 (pincode:8888)
Google drive:
2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bookworm_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1cvj-rhe9ilbD6UQdxP55RQ?pwd=8888 (pincode:8888)
Google drive:
2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bullseye_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1vmSHl0Kb58Qd9m5VE8waJg?pwd=8888 (pincode:8888)
Google drive:
2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_buster_legacy_5.4.195_xfce_desktop.img
Baidu cloud:
Google drive:
2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_jammy_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1EuIrdU66PZ_sPIIAmOo9Lw?pwd=8888 (pincode:8888)
Google drive:
2024-01-25-ubuntu-20.04-mate-desktop-vpu-npu-bpi-m6-aarch64-sd.img
Baidu Cloud: https://pan.baidu.com/s/1IUDdKI0lT53-jFqUgqrdGA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1mw0Fiwa0fmXyTs6c6DI9Z4bcQZEy83p2/view?usp=sharing
